It is currently Mon Aug 03, 2026 1:19 am
 Post subject: Tiger Dagger dimensions
PostPosted: Thu Apr 26, 2012 2:29 am
Need to make some covers for the daggers on an '02 Tiger. Could someone kindly provide some rough dimensions please? Daggers are not in my possession at the moment as they are getting filled/faired from some previous mistreatment.
Jeff R
'88 H18 Jolly Mon
'10 F18 Closely Called
cramsailing.com
PostPosted: Thu Apr 26, 2012 8:41 am
Your Hobie dealer offers a really slick cover for the Tiger daggerboards that is padded and has 2 compartments - you can view it on page 33 of the sailing accessories catalog. ( link: http://www.hobiecat.com/support/catalog-request/ )
Retail is $66.99 - not sure how much it would cost to make your own or how much time you'd spend... just thought I'd give you an option.
Jacques Bernier
http://www.hobie.com/
PostPosted: Thu Apr 26, 2012 10:56 am
Jeff,
I have a Tiger DB cover that you can use for a pattern. Call or reply.
John 8)
PostPosted: Mon Apr 30, 2012 11:27 am
Thanks (both JB's)
Boat isn't going to travel this summer, so I think we'll keep the boards under a cover on the tramp - at least for now.
After considering the material cost and labor investment of doing it myself, the factory covers look pretty appealing.
Jeff R
'88 H18 Jolly Mon
cramsailing.com
PostPosted: Fri Apr 19, 2013 6:42 pm
Can someone confirm the factory chord (distance from leading to trailing edge) of the dagger. I believe its approximately 260mm. I've fared the boards away from the boat (an hour away) and just realized I might have created an issue :o . If its 260, then we're good. Otherwise I've got some sanding to do.
Jeff R
'88 H18 Jolly Mon
cramsailing.com
