It is currently Fri Jun 26, 2026 4:38 am
PostPosted: Wed May 08, 2013 6:51 am
Have the cables installed. Can t get the foam blocks back to orignal position. Any tricks to reinstalling
The foam blocks.
PostPosted: Wed May 08, 2013 12:02 pm
You just have to force them in there...they have to compress a bit. So push them until they go.
But be sure they are not interfering (touching) any of the cordage that runs behind the blocks (steering & rudder).
PostPosted: Wed May 08, 2013 1:21 pm
Tip the top of the blocks back into where they fit. Then force the bottom of the foam blocks back. It's not going to destroy the foam.
PostPosted: Wed May 08, 2013 4:18 pm
problem solved::: trick was to tip the top toward the middle of boat and pull the bottom of the block into upright position. Thanks
