It is currently Thu Aug 20, 2026 8:18 pm
PostPosted: Thu Jun 13, 2013 10:54 am
OK guys I have a 2013 Mirage Oasis and I want to install the sidekick amas on it. Where do you all think I should install them?
I was thinking just forward of the sail right behind the front seat what do you think?
I don't want to drill holes in a spot that will interferer with the ruder up and down lines or the ruder control lines so I need to know how far inboard I should mount them or don't I need to worry about that?
Help!!!!!!
Thanks!
Jason
 Post subject: Re: Sidekick Amas?
PostPosted: Fri Jun 14, 2013 10:21 pm
I just got my sail kit and side kicks today, been wondering the same thing.
PostPosted: Sat Jun 15, 2013 5:10 am
Hobie recommended behind the back seat when I called and spoke to, I beleave his name was Brendon.
I think right in front of the mast is the best place to gain the best stability. The problem with mounting it right in front of the mast is the Ama center tube is not long enough to reach out to the flat section of the hull. So I am going to have to (1) buy longer bolts. (2) design a spacer to fit in the rounded channel section of the hull so the mounting brackets will sit flat and be high enough to clear the rest of the hull.
And here I thought this would be a simple bolt on addition silly me! HA
If any one has a better idea PLEASE chime in.
Jason
PostPosted: Sat Jun 15, 2013 6:42 am
Jason
Off Topic, but when I first read this, I thought you were Tom Kirkman responding. I was about to say "Nobody has a better idea than Tom Kirkman!" :D
PostPosted: Sat Jun 15, 2013 6:44 am
If my stuff is the best anybody can come up with, then we're all screwed.
PostPosted: Sat Jun 15, 2013 6:15 pm
Kirkman. After much to do, I ended up mounting mine behind the rear seat. Nothing else made sense. you?
PostPosted: Sun Jun 16, 2013 7:12 am
I have started on a spacer to mount them in front of the mast. I will post pics when I get it finished. Probably late in the week it is poring here and I have to work out side.
PostPosted: Mon Jun 17, 2013 8:07 am
Here is how I ended up mounting my Ama's
I used a 1/4" peace of rubber from a truck mud flap and two 1/16" pieces of PVC plastic drain pipe that I heated with a heat gun and flattened. You can see it takes the shape of the Gunnel fairly well and raises the ama bar far enough to clear the rest of the gunnel. I had to by new 3" stainless bolts ( I could have used 2 3/4" bolts but they where out). It clears the mast with the D.Y.I. PVC furl and the seatback.
I hope this helps any one else who wants there Ama's up behind the front seat.
Now if we could just get Hobie to make a center tube longer just for mounting them here we would not need to do all this back yard engineering! LOL....HINT, HINT
Jason
PostPosted: Mon Jun 17, 2013 1:33 pm
Anywhere you can mount some YakAttack GearTracs, you can mount the Sidekicks with the Track Bracket kit:
In your case, you would likely attach the brackets to the arms and not the center pole.
I have not done it on the Oasis yet but you can see how it attaches here:
With this set up, you can move the Sidekicks anywhere and even use on anther kayak.
You don't have to be concerned about whether the bracket is on the center bar or the arms as you can remove the whole setup in one piece by loosening the Track Brackets. The only downside to having the brackets on the arms is that it is not as easy to stow away the arms while on the water.
Mike
PostPosted: Mon Jun 17, 2013 5:06 pm
@Wndrfl,
I'd be interested to see how well that set-up holds up on the water.
There's a heck of a lot of force exerted by the sidekicks on the
crossbar mounts when the boat leans over.
Cheers,
Mike.
PostPosted: Mon Jun 17, 2013 5:52 pm
I have been using this product for 8-9 months and using it for sailing since March. I have put some major stresses on it and it has held up like a champ.
I feel comfortable using this product under the stresses that the sail kit and my excessive mass place on it.
If you have doubts, contact Luther at YakAttack and he will present a good argument for why you should use this product.
Personally, I believe the Hobie pontoons will break off before the YakAttack bracket gives in.
Mike
PostPosted: Mon Jun 17, 2013 6:21 pm
BTW: The winds I have sailed in, to this date, have been 5-15mph. I have been out when the gusts were up to 25mph but that was not even fun with the sail completely furled. From my perspective, strong winds are a fun challenge for the Revo but gusts are not fun.
Mike
PostPosted: Mon Jun 17, 2013 8:57 pm
That looks great Jason. I took mine out for the first time with the Kicks mounted behind rear Seat. It did quite well too.
PostPosted: Thu Jun 20, 2013 9:39 am
I had it out on the lake in (for me at least) some strong wind 12-18 and it worked very well. I would feel more comfortable when way out away from shore to have one more set of Ama's behind the seat in case the wind and the wave get real big. The great lakes can be as bad as the big ponds at times!
