It is currently Tue Jun 16, 2026 7:18 am
 Post subject: Cheek Block on 16
PostPosted: Thu Aug 31, 2006 8:44 am
Any way to replace the roller in the cheek block without removing the st.st. block. Would like to glue a new roller around the shaft if possible.
Any suggestions. thanks in advance- :?:
 Post subject: Cheek blocks
PostPosted: Thu Aug 31, 2006 10:22 am
No way I have ever heard. You have to replace the whole thing. There is a lot of load on the part.
PostPosted: Thu Aug 31, 2006 2:38 pm
Update to the aussie jib halyard system and eliminate that cheeck block at the base of the mast.....The aussie system reduces the load and u will be able to tie to the cleat dirrectly.
PostPosted: Thu Aug 31, 2006 7:36 pm
agree with ALEXSAILS you will like it much better :D
Tom & Nancy Page H20 803
 Post subject: Aussie
PostPosted: Fri Sep 01, 2006 9:48 am
We still recommend routing the Aussie halyard around the cheek block to absorb flexing loads against the halyard. Then tie off to the cleat.
PostPosted: Mon Sep 04, 2006 2:45 pm
Thanks for the help but not familiar with "update to the aussie jib halyard system". Where shoud I look? :roll:
PostPosted: Tue Sep 05, 2006 9:05 am
When I had my H16 I the sheve was missing from my cheek block. I never bothered to replace it. It worked just fine for me over the 5 years I sailed the boat and it is still working for the new owner over the past 3 years.
Nick
Current Boat
In the market
Previous boats owned
'74 Pearson 30
'84 H16
'82 H18 Magnum
St. Louis, MO
PostPosted: Tue Sep 05, 2006 3:40 pm
Basically, the Aussie system moves the 3:1 from between the mast tang and the cheek block/cleat on the mast to between the mast tang and the top of the jib. Add a small cheek block just above where the top jib batten hits the mast on the same side as the stock cheek block/cleat and you'll pretty much eliminate the batten caps hanging up during a tack.
You can either build your own or buy a complete system from Hobie or Murray's. Buy a tool bag to clip on to the tramp lacing to store all the halyard line once the jib us up.
PostPosted: Tue Sep 05, 2006 10:13 pm
In building my own Aussie halyard what is the legnth and diameter of the cable which connects from the mast tang to the first block in the system? Also what legnth of rope halyard is needed to complete the system?
