It is currently Sun Aug 02, 2026 12:46 pm
PostPosted: Thu Sep 07, 2006 9:56 am
I dont know what they are called, but the rectangular blocks that are riveted to the luff at the front of the batten pockets are falling off. Are they special rivets? I need to pick up something to fix it. Also one of the rivets are broken on the jib halyard cleat on the mast. Special rivet too? Thank you.
 Post subject: Luff batten caps
PostPosted: Thu Sep 07, 2006 12:57 pm
Luff batten caps, Pocket protectors.
There is a kit with screws and nuts to replace ones that fall off. #80550005
Downhaul Cleat? Catalog shows the rivet as #8010121 That is a pop rivet that is 3/16" Diameter. You should also use a seal cap, rivet cap #8011291.
PostPosted: Fri Sep 08, 2006 7:43 am
Thanks Matt. I was wondering if I could use stainless rivets for these applications. I have both aluminum and stainless rivets.
