It is currently Wed Aug 12, 2026 10:02 pm
PostPosted: Tue Jul 09, 2013 7:33 pm
Before I go drilling, any suggestions on which side i should install the anchor trolley? Side I fish on or opposite? Does it even matter?
I figured I would ask first, and drill later.
PostPosted: Wed Jul 10, 2013 9:54 am
Probably wouldn't matter.... Presumably, you're going to fish all around the boat, so just go with whichever side you feel most comfortable handling the anchor line (e.g., whether you're right- or left-handed, deploying the anchor, clearing tangles, rapid release, etc.)
PostPosted: Wed Jul 10, 2013 11:35 am
I put mine on the right side. If I'm anchoring, it would be by the bow or stern, most probably so that's direction-neutral. When I drift, it's usually from the stern, so again it's neutral. For the few times I anchor from amidships, I can cast easier to the left (being right-handed) so that's the tie-breaker.
The good news is that I didn't drill any holes and can switch sides easily if I choose to in the future. I used thick copper wire simply looped under the ProAngler bow and stern handles thusly:
Pro Angler-14 owner
PostPosted: Sun Jul 14, 2013 5:24 pm
Perhaps I erred in my choice of placing it on the port side along with my fishfinder. My thought was to keep the starboard side clear for reentry. I'm a righty and feel comfortable with the starboard side uncluttered and completely open for casting and landing fish. I do have a Scotty downrigger mounted on the starboard side but it is aft of the seat which wouldn't inhibit reentry. I'm sure it's mostly personal choice but I thought I would share my thoughts about safety, namely, reentry. Hope this helps.
PostPosted: Mon Jul 15, 2013 8:28 am
Interesting............ I'm also right-handed and am more comfortable with my trolley, fishfinder and a rod holder on the right. I enter and bring fish aboard on the left; don't have to reach across myself to grab the leader.
As I said... whatever you're comfortable with........ :)
PostPosted: Tue Jul 16, 2013 2:07 pm
Whichever side you have your cleat on to tie off anchor line. In the Revolution it is the right side. You can add a cleat to the other side if you prefer left side.
Revo
PostPosted: Tue Jul 16, 2013 7:21 pm
Hobie Team Member
Northern Yak Angler, You bring up a good point that most don't think of. "Keep one side clear for re-entry" I have always loaded up the STBD side with "Stuff" for the same reason, although I didn't think it out in the beginning... only after a self rescue did I realize that it was a good idea to have a clear side.
Fishing is not a matter of life or death... It's much more important than that!
PostPosted: Tue Jul 23, 2013 3:12 pm
To the point of keeping one side clear for re-entry, a gear track system will help you out. I have YakAttack GearTracs on both sides of my kayak and lots of junk attached to them. I turtled this past winter and it was a huge benefit to be able to reposition the items attached to the GearTrac as it provided a clear area for re-entry and no loss of items.
Mike
