It is currently Wed Aug 12, 2026 7:27 am
PostPosted: Mon Aug 05, 2013 4:29 pm
Guys, just got my new to me PA 14. Its a 2011 model. I want to mount my transducer to shoot thru the hull but wondered if turbulance form the mirage drive would cause problems if I mounted it under the seat? Any suggestions would be much appriciated. Thanks in advance.
PostPosted: Mon Aug 05, 2013 4:38 pm
Not sure about mounting it behind the Mirage Drive. I have always mounted mine in front of the Mirage drive with NO problems.
PostPosted: Mon Aug 05, 2013 5:25 pm
There is a nice spot just ahead of the mast tube to mount the transducer....make sure it is flat to the inside hull....no or minimal air bubbles if you use marine goop.......I used "Duct Seal" in my old Outback....electrical insulating putty.....it works like clay....from Home Depot electrical dept.....cheap and allows for easy relocation or removal if desired. The Humminbird fish finder worked really well with Duct Seal.
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Mon Aug 05, 2013 5:56 pm
If you have a Humminbird fish finder, they make a kayak transducer kit that works perfect in that area in front of the sail post. There are kits for both sizes of transducers and you can mount it in that area and not interfere with the front storage bucket. Kit comes with everything you need.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Unfair Lures Pro Staff
Ziptailz Ambassador
2015 Pro Angler 14 - Papaya
2018 Compass - Sea Grass
PostPosted: Mon Aug 05, 2013 6:10 pm
Lima Eyecatcher,
I'm curious where you are from. I live in Ohio and wonder if you are nearby me. Sorry I can't help with the transducer. I'm hoping to get a Pro Angler soon myself.
Gladdly
PostPosted: Mon Aug 05, 2013 7:01 pm
Thanks guys, I will mount it infront of the mast mount. I wasnt sure if it would come out of the water there that is the only reason I was going to mount it under the seat.
PostPosted: Tue Aug 06, 2013 5:52 am
Plus, if you mount it in the front, you will see the fish sooner :mrgreen:
PostPosted: Tue Aug 06, 2013 6:01 am
Not if you anchor from the back like I do. BWAHAHAHAHA
Hobie PA14 with a mod or two
PostPosted: Tue Aug 06, 2013 11:30 am
Authorized Hobie Dealer
We mount the transducers behind the sail mast tube and in front of the Mirage Drive well. The mast tube will unscrew to make it easier to install. We then use the new Hobie 12v Battery Holder to secure the battery to the sail tube
Brad Stephens
http://www.sunjammers.com
www.facebook.com/sunjammers
PostPosted: Tue Aug 06, 2013 9:38 pm
Thanks for all the input guys. I got it mounted today. I mounted it in front of the mast post then I used a Cabelas dry box, dilled a small hole, put a rubber grommet into the hole and ran my wires for the Cabelas battery. I then was able to squeeze the box between the mast post and the mirage drive slot. I will post pics when everything is done. I liked the idea off seeing the fish sooner lol.
cron
