It is currently Mon Aug 03, 2026 12:18 am
 Post subject: Trapeze rigging
PostPosted: Sun Aug 11, 2013 9:25 am
Would love some advice from experienced Wild Cat owners on where to attach the trapeze for the helmsman. I currently have it attached to the spare bungee in the front crossbar and find it annoying to have crew pass it back when hiking. Any advice or pics would be appreciated!
Brice
Sent from my iPad using Tapatalk HD
 Post subject: Re: Trapeze rigging
PostPosted: Sun Aug 11, 2013 10:27 am
The pics are not from my Wildcat ,but the rigging is the same for the helmsman trapeze
F18 Hobie Wildcat sail nr NED 066 & NED 1111
Hobie 16 sail nr 104195 sold
470 sailnr NED 560 sold
PostPosted: Sun Aug 11, 2013 10:42 am
With the clamcleat trap height adjuster, doesn't it come uncleated when the bitter end is run up? I guess not. I assume the cleat has though bite to keep the line set.
Zach
PostPosted: Sun Aug 11, 2013 10:58 am
I never " fall " down and at the end is a knot ,and with one hand you can adjust the trap height even on the wire
PostPosted: Sun Aug 11, 2013 1:27 pm
Perfect, thanks! I had attached it to the same spot as in this picture before with a short bungee and it sagged and got in the way of the crew. I can see in these pics that I should run a bungee under the tramp to the other side. Very helpful, thanks!
Brice
PostPosted: Sun Aug 11, 2013 11:15 pm
The bungychord must go tru the rivets under the tramp
If you put the bungychord directly under the tramp ,and the crew is not out yet and sitting on the tramp
The bungychord will stuck between the hull and tramp
PostPosted: Fri Aug 16, 2013 2:43 pm
Makes sense, thanks!
