It is currently Thu May 14, 2026 5:04 pm
 Post subject: Biker Rash
PostPosted: Mon Jul 08, 2013 2:23 pm
I spend from 8-13 hours on the water when I go fishing and get varying degrees of biker rash on my N***. It can be very painful. I can't be the only one getting this. I wear dri-fit compression shorts under my swim shorts. I have also tried vaseline and an aloe gel. Both help but eventually will get washed away. Any suggestions will be appreciated.
 Post subject: Re: Biker Rash
PostPosted: Mon Jul 08, 2013 4:02 pm
Spray some Never Wet on them :oops:
PostPosted: Tue Jul 09, 2013 7:28 pm
WD-40... lubricates and displaces water :lol: :lol:
PostPosted: Tue Jul 09, 2013 9:05 pm
revo fish:
I used to have the same problem, I ended up making spray skirts for my TI so now almost no water splashes into the cockpit anymore. I also cut up an old pool mattress, one of the 1 inch thick latex foam covered with rubber types (yes they are very expensive, and I did get in trouble for it). But it works perfect, I slide it under the kayak seat, and it raises me up about an inch or so, and my bum now stays much drier.
I used to always wear my swim suit, and always had rash problems by the end of the day. Now I just wear my regular shorts and underwear, and they stay dry, and haven't had any rash problems since. An added benefit of the latex pad is it's way more comfortable, after a few hours of sitting in the standard Hobie kayak seat, my bum would get very sore, the pad helps in that area also.
Hope this helps
PostPosted: Wed Jul 10, 2013 4:22 pm
Get rid of the cotton underwear. Go to Victoria's Secret and get a couple pair of silk panties problem solved. Doc Irv told me this would work, haven't tried it myself...
OK, seriously, this is probably too much information, but I wear an athletic supporter and quick drying nylon fishing shorts. Moisture is your enemy, ventilation of the nether regions would help, and swim shorts with mesh liner (no underwear) may do the job.
2012 PA-14 Dune; 2013 PA-14 Yellow.
PostPosted: Thu Jul 11, 2013 5:17 am
A small bit of "diaper rash ointment" on the affected area helps akot. The ointment will not wash away as fast as other creams.
Jim
PostPosted: Tue Jul 23, 2013 2:29 pm
On long bike rides (30-75 miles), we use Chamois Butter aka "Butt" Butter. Just Google the name.
Mike
PostPosted: Tue Jul 23, 2013 3:11 pm
It's mini lobster season down here in Florida the next two days, we plan on going out both days and will be out all day in wet trunks all day. Someone said diaper rash stuff would work so I went out and bought a huge tube of A&D ointment, so I will remain baby fresh hopefully all day. However when we go to the manly bar after diving, what the heck am I supposed to say about the baby fresh fragrance, I don't want to get beat up (LOL).
PostPosted: Tue Jul 23, 2013 4:39 pm
We've made many a stops at Alabama Jacks on Card Sound Road, in the Keys, all slathered up with butt butter and wearing those stupid spandex cycling shorts. The key to survival is to out-drink anyone who challenges you. :evil:
Mike
PostPosted: Tue Jul 23, 2013 4:53 pm
Or, be able to outrun your buddies:D
PostPosted: Tue Jul 23, 2013 7:19 pm
You only have to outrun one! :D
PostPosted: Sun Aug 18, 2013 10:52 am
You can also try Gold Bond powder. I think it helps a lot.
Sent from my iPad using Tapatalk HD
PostPosted: Sat Aug 24, 2013 12:06 pm
Monistat Chafing Powder Gel is the best stuff going!!
I use it for motorcycle riding as well.
http://www.walmart.com/ip/Monistat-Chaf ... z/10293929
PostPosted: Fri Sep 06, 2013 5:46 pm
Try Body Glide - no mess, doesn't stain, and you won't sweat it away. Most running stores have it.
PostPosted: Sat Sep 07, 2013 12:45 pm
Try a lotion called chamois butt'r. Made for cyclists and sold in bike shops. Same problem, same solution.
