It is currently Mon Jun 15, 2026 8:36 pm
 Post subject: Rudders up under sail?
PostPosted: Mon Aug 26, 2013 5:11 am
Hi,
I was looking at this picture, admiring their extreme mast rake, when I noticed that their rudder(s) is/are up!
I initially thought it was some sort of fluke, but then I saw the same thing in another photo a few minutes later:
Their rudders (or at least the windward rudder) appear to be in the UP position while under sail. My H16 is an `81, and judging how brassed off the finish is on the cross bar, the tiller mechanism is probably original, so maybe something has changed, but I struggle to envision how you would do this while under sail. (Not to mention that I've had enough trouble with H16 rudder cams over the years that I would be hesitant to tempt fate by locking and unlocking them frequently.)
Can someone explain what's going on? Are they unlocking just the windward rudder? How does that work with the tiller? On mine, when the rudders are in the up position, the tiller crossbar sits several inches below the main rear crossbar, and having the tiller extension going up over that main rear crossbar causes the rudders to come out of the "locked up" position. I guess in both pictures the helmsmen are out on the wire, and in the second pic, you can see that he's holding the stick such that it's not touching the main rear crossbar, even bought the tiller crossbar (such that we can see it in this photo) is sitting below the main rear crossbar.
I guess I can see the motivation -- less drag is less drag -- but what are the practical mechanics of this?
Ian
PostPosted: Mon Aug 26, 2013 6:23 am
While your '81 and these ~2008/2010 boats are both Hobie 16s and are superficially identical, there are several design changes in the rudder system since the '80s that cumulatively make a huge difference in performance.
The rudder kick-up system on newer boats just works. Rudder goes down smoothly, 'click' - it's locked down - and if it's very new, there will be virtually no slop in the entire system. Quick jerk up and forward and cam releases, the rudder comes up, and stays parked in the up position. It just works. It's hard to explain to someone who's struggled with their rudders on an old boat how well the system works when it's been adjusted properly.
As for the technique in the photos - only the windward rudder is up, and yes - the lockdown system works so well that they change on every tack. The top (younger) skippers are proficient enough to pop the rudder up with their rear foot while on the trapeze.
As to why they do it - there are two reasons 1) it forces you to foot going upwind. In heavier air, the Hobie 16 makes better VMG to weather when you foot rather than point, which requires more rudder movement. With only one rudder in the water, you'll stall out if you try to point. 2) in heavier air, the part of the windward rudder in the water is very draggy, so you put the rudder up to get rid of the drag.
This is a very advanced and somewhat difficult upwind technique to master (the first photo is of 2007 world champions Mick Butler and Susan Etherington). You'll only see the very top of the fleet at a major championship use it.
PostPosted: Mon Aug 26, 2013 10:52 pm
I've done this a couple times on my '80 H16.... Kinda just happened naturally when i was screaming along in heavy air..... Both times the leeward rudder snapped in half within about 10 mins. The OEM older plastic rudders cant take the strain or weight, however it was some fun fast easy steering while it lasted! Got a 90's EPO full setup with the adjustable castings now... just need to put them on.
Tim
Tim Grover
Memphis, TN fleet 134
Hobie 20! G-Cat5.0 and 2 Hobie 14's
Photobucket now wants $100 to post pics on forums......... pass.
PostPosted: Tue Aug 27, 2013 6:33 am
I was out yesterday and gave this a try. It made a HUGE difference. So much of a difference in fact, that I beached the boat to check the rudders, and discovered a HUGE unintentional toe-in (I'm guessing my crossbar adjustment got banged in somehow). After re-trimming the rudders (such that I could with what tools I had on me) the boat was moving MUCH better in general. Kicking up the rudder still made a difference, but far less of a difference, and seemingly only if the hull was totally out. Thanks for this teachable moment, folks!
Next project: tightening up the rest of the rudder/tiller system, and adjusting the rake to get rid of (some of) this weather helm.
Ian
PostPosted: Wed Jul 19, 2017 8:57 pm
I can't even keep my rudders locked in the up position when beached or on the trailer. Even though I've overhauled the rudders and replaced the parts, one rudder will always drop when the opposite is brought to the up position. Is it just the nature of rudder systems on older boats (my Hobie 16 is an '88) as mentioned in one of the above posts or is there a way to fix this? Sorry, likely a dumb question.
Andrew
'88 Hobie 16
PostPosted: Thu Jul 20, 2017 9:53 am
JePense wrote:
I can't even keep my rudders locked in the up position when beached or on the trailer. Event though I've overhauled the rudders and replaced the parts one rudder will always drop when the opposite is brought to the up position. Is it just the nature of rudder systems on older boats (my Hobie 16 is an '88) as mentioned in one of the above posts or is there a way to fix this? Sorry, likely a dumb question.
That will often happen when the tiller extension is laid forward on the trampoline. The connection (with both rudders up) is below the level of the crossbar, so something has to give.
Try it with the tiller extension off to the side. (Obviously, you take the tiller extension off to trailer.)
