It is currently Fri Jun 26, 2026 11:34 am
PostPosted: Mon Aug 26, 2013 8:56 pm
I use a livewell so I can't put it through my rear scuppers, and I tried putting it on my anchor trolley, but it just stretches and the WaNG lays flat in the water, and then my anchor trolley broke! Any suggestions on mounting it s I can use the thing? I own a 2013 Pa 14
PostPosted: Tue Aug 27, 2013 1:08 pm
What is a Wang SOP?
PA 14 Dune
PostPosted: Tue Aug 27, 2013 1:44 pm
I have a 6 foot Wang Stake Out Pole (SOP) and understand where you are coming from. It's been my experience that an anchor trolley is better suited for an anchor versus trying to get a SOP to stay in place. The scupper holes do provide the best avenue for inserting the SOP since you're using that length of internal tubing in the scupper to hold the SOP vertical.
I can see how having the livewell in the rear would reduce you to the front scuppers and depending on the water depth, the pole would definitely get in the way. My thought would be to come up with a small PVC tube or something similar that you could mount to one of the side rails near the rear to use as a SOP holder. That way it would be slightly behind you and not in the way.
Scotty makes a rod holder that is basically a tube that comes in a rail mount that might work. It might be worth looking into or making something similar. Good luck!
Scotty example: http://www.scotty.com/fishing-gear-equi ... 20copy.jpg
The Wang SOPs are very nice and I really like mine.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Unfair Lures Pro Staff
Ziptailz Ambassador
2015 Pro Angler 14 - Papaya
2018 Compass - Sea Grass
PostPosted: Tue Aug 27, 2013 2:00 pm
JollyOgre wrote:
What is a Wang SOP?
It's a stake out pole, (sop). Wang is the model name.
PostPosted: Tue Aug 27, 2013 3:50 pm
I would never put a SOP through a scupper. I know Hobie has reinforced the scuppers but ...... I use an anchor trolley and simply clip my SOP onto the trolley. I have a 4 ft piece of cord between the SOP and the trolley clip. If I want it shorter, I simply put a loop knot in the cord.
For storage, I lay the SOP along the side with one end on the outside of my rear Hobie rod holders, lay the length of the SOP on the inside of the rail, and put the top part of the pole on the outside of my fishfinder which is mounted on the front side boards.
PostPosted: Tue Aug 27, 2013 4:44 pm
I use my anchor trolley to hold my 8' ParknPole without issue. Another option that YakAttack just released is the Zooka Tube. Here is a video of how it could be used ...
[youtube]http://www.youtube.com/watch?v=-gja5EZPFsc&feature=youtu.be[/youtube]
PostPosted: Tue Aug 27, 2013 8:40 pm
I also use an 8' Park and Pole with my Anchor Trolley. Not one Problem, I do however keep the PNP on a leash and attach the leash to the anchor Trolley.
PostPosted: Wed Aug 28, 2013 5:54 am
The few times I have used the scuppers are when I was in water without a current. So no worries on applying too much stress on the scupper holes. The only scupper holes I would use are the re-enforced ones for the cart. I am looking at getting a pair of those Zooka tubes for the 2013 PA14 and using my current rod holders on the 2012 PA14. Using one of them as a Stake Out Pole holder might be an option.
It sounds like others have had better success using a SOP in the anchor trolley than I have. I'm sure a lot of it depends on the conditions and type of bottom you are trying to secure the SOP into.
Thanks for providing that Zooka Tube video. Sold me on getting a pair of them. :D :D
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Ziptailz Ambassador
PostPosted: Wed Aug 28, 2013 10:06 am
[code][/code]
Good deal! I am thinking of getting a couple my self. Luther did a seminar at Mariner Sails a few weeks back and ever since he showed us that extra use of the zooka tube I can't get them off my mind. I will be selling off my current holders to upgrade. :wink:
PostPosted: Fri Aug 30, 2013 3:25 am
I attach mine to my trolley but if you don't like that you could just make a loop with a cord on your side rails and stake the pole down through the loop.
