It is currently Sun Aug 09, 2026 9:53 am
PostPosted: Tue Aug 27, 2013 5:45 am
I picked up some Preval 267 Sprayers and finishing Gelcoat. Am I going to need to thin the Gelcoat or will the Preval sprayers handle it without thinning?
What is the most affordable thinner to use, if that is necessary?
Broward County, FL
1984 Hobie 16, Olympic Edition (kept in NY)
PostPosted: Tue Aug 27, 2013 8:35 am
You need to thin it. I used to use acetone. Thin to a milky consistency. Spray light / thin coats and wait a bit between each (10 seconds?)... been a long time though!
PostPosted: Thu Sep 12, 2013 4:56 pm
Thin with styrene.
PostPosted: Fri Sep 13, 2013 7:11 pm
Second the styrene. Especially white gel. Thin until sprays evenly, use a test surface. Apply thin coats as Matt says, wait a couple of minutes between coats. Last coat should have "sanding aid" added to allow for proper anerobic curing and ease of sanding out of "orange peel" hardened surface.
ADDICTION
1989 HOBIE 18 SE/sx wings
HOBIE ALTER SIGNATURE MODEL
PostPosted: Fri Sep 13, 2013 7:33 pm
+2 on Styrene - Put down a couple more coats than you think you need. Prevail sprayers with thinned gelcoat take several (many?) coats to build up a decent layer of gel on the boat. It's much easier to do a little extra sanding than have to respray after you've sanded through a too-thin layer of Gelcoat.
