It is currently Fri Jun 19, 2026 4:22 pm
 Post subject: Painting mast
PostPosted: Sun Oct 13, 2013 12:58 am
Hi guys I am new to this forum. I have a old boat which the aluminum is starting to oxides and would like to paint/spray it black. How do you remove anodizing if necessary and what under cote/ primer can I use. I got suggested Zinc chromate or epoxy primer? Thanks
 Post subject: Re: Painting mast
PostPosted: Mon Oct 14, 2013 9:25 am
Just sand the mast. I would use a self etching primer with and epoxy paint. I believe David Bell just used Black Primer on his. you would need to search his post.
PostPosted: Mon Oct 14, 2013 9:30 am
Zinc Chromate is nasty stuff. I would suggest you read up on the MSDS sheets before considering messing around with it.
PostPosted: Mon Oct 14, 2013 11:04 am
I spoke to some this afternoon and he suggested to just have the mast epoxy coated... is that a option???
Have great day
Johan
