It is currently Wed Aug 12, 2026 9:37 am
PostPosted: Fri Oct 18, 2013 10:16 am
I am looking for a fish bag or cooler that fits the front trunk on a PA14. I have put fish in the trunk with some ice but it doesn't work well since there is no insulation and if it is sunny the compartment heats up big time. Of course I can put a cooler on the back but usually have my live bait cooler and other stuff back there.
Any ideas or experience would be much appreciated. I have seen where folks insulate the front cover but I am looking for something more effective than that.
Alan
2012 PA14 Papaya
2014 PA14 Dune
"If you must choose between two evils, pick the one you've never tried before!"
PostPosted: Fri Oct 18, 2013 8:33 pm
I use this bag for inshore fishing. All it takes is three frozen 20oz bottle of water to keep the fish cool for 6 to 8 hours in direct sunlight; less than 5 hours or if the bag is not full your fish will probably freeze.
It's small enough to put in the front hatch.. but I prefer to leave it on the rear deck.
http://www.austinkayak.com/products/938 ... h-Bag.html
PostPosted: Sat Oct 19, 2013 7:08 am
Or, make your own! If you search the archives of this forum, you will find a thread about using spray-in foam to insulate the front tub and lid, converting the whole hatch compartment area into a cooler.
PostPosted: Sat Oct 19, 2013 7:29 am
Thanks Jim, yes I have seen that. Also have seen where folks put some sheet insulation in the lid with spray adhesive.
I am still wondering if someone make a bag to fit. There are enough of these boats out there now that surely someone is making a bag of a box to fit.
Alan
2012 PA14 Papaya
2014 PA14 Dune
PostPosted: Sun Oct 20, 2013 3:37 am
Ive researched this i think the surf to summit & the precision pak based on design and reviews etc. are..the best optionsImage....
PostPosted: Sun Oct 20, 2013 8:11 pm
I have a PrecisionPak and it works well on my back deck. Not sure which model it is, but it looks like the jpg in your post, and I don't think it would fit in the front coffin. It would fit if you remove the tub, but would be hard to load a big fish into unless you pull it out onto the deck. I put several 1" thick frozen gel packs in it and that keeps it everything very cold (fish, drinks, bait) for about 6 hrs in 80-F summer temps. One problem I have is that it will not hold more than a few large fish (1-20# salmon, 2-3 10# lake trout, etc). So on a good day, it takes several trips back to the truck cooler to keep your catch fresh. I keep my catch in the inner dry bag liner because that helps keep the slime off the inside of the cooler itself. It could hold more large fish if you did not use the dry bag liner.
PostPosted: Sun Oct 20, 2013 10:09 pm
Thats good info thx i think the surf to summit makes a big one that could fit nicely on top the hatch
