It is currently Fri Jun 19, 2026 7:38 am
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
PostPosted: Sat Oct 19, 2013 7:03 am
What line is the new boats coming with and what diameter.I know they use to come with pretty cheap stretchy 1/4" line,but now it is closer to 5/32" pre stretched line.Would like to know make of it so I can order some.
PostPosted: Mon Oct 21, 2013 12:40 pm
Can I order this line thru my Hobie Dealer?Asked him already and all he is showing is the old 1/4" white line.Also want to order length for double grommeted center,so probably need 40' for center.
PostPosted: Mon Oct 21, 2013 1:06 pm
We don't stock the line used in new boats (Liros). The line comes only in complete line kits coming from Australia at the moment... main sheet, jib sheet, laces etc. You can get a complete line kit if you want.
I'm trying to get bulk line in for the next catalog.
In addition, new boats / trampolines will be coming with the double grommeted center lace soon. I don't have the line length spec yet.
PostPosted: Mon Oct 21, 2013 1:34 pm
Any Hobie dealer should have new replacement lines. Just order more of it!
PostPosted: Mon Oct 21, 2013 2:19 pm
In the mean time,can you give me the line diameter and recommendation of line bought here in N.A. That most closely resembles what is in the new boat package for tramp lacing.I will figure out the length.
PostPosted: Tue Oct 22, 2013 6:32 am
Center Tramp Lace 1/4" Halyard x 19' 1 ea.
Aft Tramp Lacing Line 1/4" Halyard x 15' 2 ea.
http://www.apsltd.com/c-1502-finish-lin ... gland.aspx
http://www.apsltd.com/c-1505-sta-set-new-england.aspx
These just a few that I saw on their site.
PostPosted: Tue Oct 22, 2013 8:30 am
Both those lines are very stretchy. Is there a prohibition on spectra/dyneema tramp lines?
If not, I'd highly recommend something with a spectra/dyneema core, to allow you to keep as tight a tramp as possible.
1990 Hobie 18SX #2077
PostPosted: Tue Oct 22, 2013 8:34 am
As noted the new line coming with boats is not available... yet.
The line recommended is simply 1/4" # RH014WHT
Lengths are always in the parts diagrams in the catalogs (also noted above... and now center laces will be getting longer for the double grommeted trampolines).
PostPosted: Tue Oct 22, 2013 3:00 pm
Yes ,sure ,thanks Matt.We all know what the standard white line is listed in the Catalog is. We also know that that line is crap to put on your tramp.Way too much stretch.
Guess we just have to wait for you guys to get the stuff in that you are using already.
PostPosted: Tue Oct 22, 2013 5:09 pm
http://www.liros.com/produkte/yachting/dinghy.html
Hobie now uses Liros lines for sheets/lacing. i believe the Magic Gold is the tramp lacing. most likely 5mm.
not available in the US unless you buy a Hobie, or wait, as Miller says.
any 5mm or 6mm dyneema/vectran line will work well - or if you prefer the budget route any low stretch poly line such as some of the stuff Murrays sells.
PostPosted: Tue Oct 22, 2013 7:19 pm
Put me down for 60' of the black with blue and gold tracer.That would look sharp on my turquoise tramp.
PostPosted: Mon Feb 24, 2014 2:15 pm
Matt did you guys bring some line home with you.Any specs on length?
PostPosted: Mon Feb 24, 2014 3:42 pm
Still ironing out the supplier details (we have none here and have not yet had enough information to place an order), but here is the specs for a current Hobie 16 kit (tramp center lace is now double grommeted):
Item Size Meters Feet Rope type Colour
centre tramp lacing 4mm 10 32.8 Magic Gold black/yellow/blue flec
aft tramp lacing (x2) 4mm 4.5 14.76 Magic Gold black/yellow/blue flec
righting line 10mm 5 16.4 nautic yellow
main sheet 9mm 11 36.09 magic sheet silver white flec
jib sheet 7mm 10 32.81 magic sheet orange/white flec
main halyard 5mm 11 36.09 hercules colour blue (non-Comptip Halyard only)
jib halyard 5mm 21 68.9 magic d pro yellow
jib traveler line (x2) 5mm 4 13.12 magic gold red/yellow/blue flec
travelere shock cord 4mm 0.8 2.62 sandow / gummileine black
cunningham line 4mm 1.5 4.92 white dacron supplied by HCC
boom outhaul 4mm 2.4 7.87 supplied w/sail via HCC white
trapeze adjuster ropes (x2) 5mm 1.1 3.6 magic gold yellow/red/blue flec
trapeze shock cord (x2) 5mm 2.1 6.8 sandow / gummileine black
PostPosted: Mon Feb 24, 2014 3:52 pm
Thanks Matt,those colours for the Tramp lacing line look very nice.
So your saying there is a chance (said in my best Jim Carry voice ,in Dumb and Dumber) that you may get some of that Magic Gold Line in?
PostPosted: Mon Feb 24, 2014 5:06 pm
Mike, you coming to the Minneapolis area any time soon?
I'd lace it with 3mm dyneema myself. I've got a couple spools of yellow. I think its about $.30/ft. I might have some red too, but it turns pink in a hurry. Robline had a black that was sweet, but it got discontinued or changed and I stopped buying it. Might have some 2.5mm blue too come to think of it.
Otherwise I could mail it to you.
