It is currently Thu May 14, 2026 3:36 pm
PostPosted: Tue Dec 17, 2013 9:12 am
hello ... sorry for the bad english language
I ask you if you too have heard of a broken rod / pedal arm of a unit mirage drive?
These photos are for a revolution 13.
  Purchased in February 2013 in Italy
Use with fins medium ST (NO TURBO!).
it is possible that they are so weak / soft?
  Do you have similar stories?
thanks for an answer
maurizio ( Italy)
PostPosted: Tue Dec 17, 2013 10:01 am
While that is a somewhat unusual failure location... we have seen some. Not sure the issue. Possibly a extrusion process problem. his would be covered by warranty, so contact your dealer.
PostPosted: Tue Dec 17, 2013 12:21 pm
the problem was quickly resolved within 48 hours from the dealer BY with great satisfaction ....
but if it was not under warranty?
  this potentially serious problem if there are other situations alike
PostPosted: Tue Dec 17, 2013 2:24 pm
Potentially serious? I suppose in the worst possible situation it could be a bigger problem. You can pedal with one pedal and even one fin, we include a paddle with every boat. The same issue with a flat tire on a car... you have a spare, but you could get stuck in a bad spot.
