It is currently Thu Aug 13, 2026 4:33 am
PostPosted: Sun Feb 09, 2014 6:50 am
What is New in 2014 for Revo 13 compaired to 2012 and also any changes on pro angler 12 this year ? Looking at both any help would be welcomed. Choosing the right 1 is the hard part.
PostPosted: Sun Feb 09, 2014 6:33 pm
I have heared Hobie came up with a bigger rudder to help the stearing tracking problem on the Pro Angler 12 and 14. Will this be on the 2014 model ?
PostPosted: Mon Feb 10, 2014 4:50 am
@bobsdream,
Per Matt Miller at Hobie(paraphrased):
It will fit any PA 12 or 14, but is over-sized and due to that... is not a "Direct" replacement in that is exceeds some of the design conditions for the Pa 12 and 14. It extends aft of the handle. It extends aft on the loading skids, so will require careful handling or slight modification for loading using the skids.
This is a optional accessory for added rudder authority. It is not a retrofit or warranty replacement.
Taken from this string: http://www.hobiecat.com/forums/viewtopic.php?f=78&t=50247
Mike
PostPosted: Mon Feb 10, 2014 9:24 am
2014 Revo13 has the transducer mount now. That's a big deal for the Revo line.
PostPosted: Mon Feb 10, 2014 12:12 pm
As there was no inherent problem with the Pro Angler steering, the larger rudder is just an accessory. Sort of like the sailing rudder offered for the other Mirage Drive kayak models.
