It is currently Wed Aug 12, 2026 11:03 am
 Post subject: PA Carts
PostPosted: Fri Feb 21, 2014 9:52 am
Hey Guys
What are you guys using for carts? I heard the scupper carts can cause cracks/leaks. I do both sand and ramps when launching,
Any and all info would be much appreciated.
OL Sarge
2014 Pro Angler 14 Dune
2013 Outback Papaya
Military Police, USAR SFC
Broward County Florida
 Post subject: Re: PA Carts
PostPosted: Fri Feb 21, 2014 10:50 am
The scuppers are reinforced on the PA's. You shouldn't have any problems using the Hobie Trax cart. One thing you need to is to make certain the tires do not rub on the PA.
PostPosted: Fri Feb 21, 2014 7:46 pm
Ditto, the Factory Wheeleez cart, make sure you add metal valve caps if you are going to be in the salt. No caps in the salt will destroy the Shrader valve in no time .
Steve
Bassyaks
PostPosted: Sat Feb 22, 2014 7:00 am
I use the Hobie dolly. My dealer recommendedit over the scupper carts because of the weight of the Pro Angler. The dolly is very heavy duty.
Sent from my Galaxy Note 10.1 2014 Edition
PostPosted: Sat Feb 22, 2014 8:42 am
They make the Trax 2.30 for the PAs. It is a bit more heavy duty that the standard Trax cart. Costs $25 more as well. But Hobie does not recommend storing the kayak on the cart.
