It is currently Mon Aug 03, 2026 10:18 am
PostPosted: Sun Feb 02, 2014 3:46 pm
Why can't they make these out of something that doesn't break. I have had many of these fail over the years. Now I double them up or just tie a knot behind the broken pieces. Too bad it's and issue at Worlds on brand new boats.http://hobieworlds.com/hobie16-worlds/results-2 click the "Protests" spot
PostPosted: Sun Feb 02, 2014 9:10 pm
Are they switching from boat to boat after like each day or anything?? or do they stay on the same boat for the entire event?
PostPosted: Mon Feb 03, 2014 5:59 am
Switching boats.
PostPosted: Mon Feb 03, 2014 9:47 am
Why Not Billet??? Would not weight much...........
PostPosted: Mon Feb 03, 2014 10:09 am
I have thought about using one of those washers like the sell for the rudder system, and a figure of eight knot...
I am figuring on doing a couple of eye splices and some other things to clean up my setup soon...
Thinking I may make some Aluminum stoppers..
www.thehobiewayoflife.com
PostPosted: Tue Feb 04, 2014 6:27 pm
Improper lace is the major cause of failures check the rigging manuals for proper threading.
Starting from the trap dog bone thru the wire eye... Into the lock across the depressions and out the far side... Then twice around under the loop and then to the bungee.
PostPosted: Wed Feb 05, 2014 7:58 pm
Hey Matt, please update the photo in the catalogue.
1984 H16 "Mister Rogers"
1984 H14 "Sundays"
2000 H20 "Jet"
Sheet In, Max Out
PostPosted: Wed Feb 05, 2014 9:29 pm
What page?
PostPosted: Sat Feb 22, 2014 9:28 am
Page 7 of the 2013-14 Winter Parts and Accessories. You'll see it under Rope Lock.
PostPosted: Mon Feb 24, 2014 10:13 am
The photo is correct except for a second pass around was used at the Worlds (smaller diameter lines). The key is that the right side in the drawing would be up against the wire thimble.
