It is currently Tue Mar 10, 2026 7:16 am
 Post subject: One Piece Trampolines
PostPosted: Sat Oct 30, 2010 10:23 am
I think hobie should include an option on their boats to have a one piece trampoline. totally iliminate the anooying mainsheet through center lacing thing. This is what I'm talking about
Whadya think?
'72 Hobie 16
with
#56 Gonzo Nationals
PostPosted: Sat Oct 30, 2010 11:08 am
Been done before (early '90s) - and abandoned.
Can't get enough tension on the tramp (just look at the wrinkles on the example).
The mainsheet tends to go over the rear crossbar, anyway. This doesn't solve that problem.
PostPosted: Sat Oct 30, 2010 5:01 pm
I second that, the side crossbars should be slightly bent in from the tension.
PostPosted: Mon Nov 01, 2010 7:32 am
I don't really think the 2 piece tramp needs to be changed but, what if there were laces on all 4 sides of the tramp? I would think that would pull it tight.
1979 Hobie 16
PostPosted: Wed Nov 10, 2010 3:07 pm
I believe that we actually have a one-piece trampoline that was built specifically for our Hobie about a year ago. After we bought our Hobie, the trampoline was ripped when it went into storage for the winter and it had to be replaced.
PostPosted: Thu Feb 27, 2014 1:59 pm
I use the center lace as a foothold sometimes.
PostPosted: Thu Feb 27, 2014 5:42 pm
The photo that Janet.w posted is still a 3 piece trampoline. Notice the lace on the port side near the side rail. This doesn't seem to solve any thing. Trampoline tension would not be even and it would be uncomfortable on port tack. I agree with miller, I often use the center lace for foot holds and to store the righting line.
John Latimer
'79 Hobie18 - Magnum
Sail#4854
PostPosted: Sat Mar 01, 2014 3:10 pm
What about a bias cut and just lacing it in the rear?
PostPosted: Mon Mar 03, 2014 11:44 am
As a tall guy I often have my righting line thread through the center lacing so I can use it as a hiking strap.
www.thehobiewayoflife.com
PostPosted: Thu Mar 06, 2014 8:56 pm
why don't we do what the getaway does, put a marrow piece of tramp material under the lacing in the middle.
PostPosted: Fri Mar 07, 2014 9:48 am
You can always just add a Mainsheet Overboard Preventer (it's a kit sold through Hobie Dealers - part #2067) Does the same thing as the Getaway tramp...fills that gap with mesh material.
Jacques Bernier
http://www.hobie.com/
PostPosted: Sun Mar 09, 2014 8:39 am
my hc 16 has an aftermarket tramp that has a diagonal closure It is very very tight and has no place for the main or jib sheet to fall thru The closure is covered by a flap of tramp material with Velcro
It is on the third summer and has held up very well
The boat is a 1985 and not used for racing
Former hobie admiral Gary
