It is currently Fri Jun 26, 2026 12:39 pm
Post new topic Reply to topic  [ 60 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Tue Mar 11, 2014 11:41 am
I've been thinking about doing a seadek kit for my PA14 for a while now but haven't pulled the trigger. What would really help me pull the trigger is for those who have the kit to tell me about their satisfaction, as well as how many millimeters thick their kits are. Thanks guys! this is Pretty much a branch thread
PostPosted: Tue Mar 11, 2014 1:13 pm
I'll try to answer your questions. If you get a single color kit (one off the website) the padding is 5mm thick. If you get a 2 color custom kit, the total thickness is 6mm as they sandwich two 3mm layers to make the 2 color padding. SeaDek offers padding up to 20mm thick. I'm sure that thickness is used for Helm station pads and other marine applications that require thicker material. They do not like to use the black color as a top color. Any other color is available as a top color for a 2-color project. I've seen 3 and 4 color versions of padding they make that look great. Talk to Paige Brewer and she will gladly answer all your questions.
I love the SeaDek as it totally changes the feel of the decking. You do not get the impression you are stepping on a plastic deck. The material helps to reduce sounds from movement and objects striking the deck surface. I have yet to see where I did not have great footing (either barefoot or with shoes) when the decking gets wet. I have the micro-dot pattern on the surface of my SeaDek. You can get it in a smooth surface as well. Water beads up on the material and does not get absorbed by it.
I am in the PA several times a week for hours fishing. So far I have had zero issues with cleaning the SeaDek after each outing. If I have fish blood, Cyprus gum or anything that does not wash off easily with soap and water, I use a little Turtle Wax Bug and Tar remover and a small stiff hand brush and whatever had dried on from being in the sun all day comes off easily. Hope this helps you out.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Unfair Lures Pro Staff
Ziptailz Ambassador
2015 Pro Angler 14 - Papaya
2018 Compass - Sea Grass
PostPosted: Tue Mar 11, 2014 1:17 pm
You must be a salesman haha my mind is set :mrgreen: what would you say is the ultimate difference between dimpled and smooth? I want the aqua camo.
PostPosted: Tue Mar 11, 2014 2:15 pm
On the solid colors the smooth finish came across as lightly streaked and not completely solid. If you're getting a camo pattern I do not believe that would be a concern. Here's what the camel color I chose looks like in the other finish.
http://www.flickr.com/photos/58766789@N03/12819818824
I have not seen a pure solid smooth surface. You can ask Paige at SeaDek about it. I like the micro dots as they give the decking a little more character...lol.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Ziptailz Ambassador
PostPosted: Tue Mar 11, 2014 2:30 pm
The "solid" ones on that flickr link look like brushed wood. Actually looks pretty cool like that. But I think ill go with the dimples, not sure how those streaks will look with the camo
PostPosted: Tue Mar 11, 2014 3:00 pm
You should not have those streaks with a camo pattern. Just verify with Paige at SeaDek. The camo with micro dots (dimples) should look very nice.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Ziptailz Ambassador
PostPosted: Wed Mar 12, 2014 5:20 pm
My kit has not been delivered yet, but what I found most helpful (besides Steve's pictures and personal knowledge base) was a series of YouTube videos that SeaDek has done. If you go to the SeaDek Home page, click on the YouTube window on the upper right side of the page, it will start a series of videos that are extremely helpful in learning about the product. Most of the videos are about the various uses of the product, not specifically about kayaks but they do show how to apply it, how to keep it clean, and even how to replace the pads if that need arises in the future.
Richard Laughlin
Richard Laughlin
Lafayette, LA
Finally Retired, Fish Beware!
2013 Hobie Pro Angler 14
2012 Hobie Pro Angler 12
2001 Hobie Hank Parker Edition Outback
PostPosted: Wed Mar 12, 2014 5:32 pm
Richard Laughlin
Thanks Richard I will definitely look into that
PostPosted: Fri Mar 14, 2014 7:42 am
Just placed my order for the micro dot aqua camo. I think it'll look nicely on a yellow PA, but I might be biased to those colors.... CHARGERS!!!!!!!!!
PostPosted: Fri Mar 14, 2014 12:36 pm
How much weight do the seadek mats add to the kayak?
PostPosted: Fri Mar 14, 2014 1:21 pm
Different kayaks have different layouts so it varies but I don't think it'll be more than a pound? I've never used seadek before so my opinion could be way off
PostPosted: Fri Mar 14, 2014 1:22 pm
I can give you a guess or approximate weight. Each of my custom kits with the packaging was about 9 pounds. So I would guess around 7.5-8 pounds since some of what is shipped are cutouts that are not installed.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Ziptailz Ambassador
PostPosted: Fri Mar 14, 2014 1:52 pm
Wow I was way off haha
PostPosted: Fri Mar 14, 2014 2:13 pm
Thanks for the info! Nice to know. I think I'll pass on adding any extra weight to my PA, but it sure does look nice.
PostPosted: Tue Mar 18, 2014 1:23 pm
fishwisperer....I would really be appreciative if you could post a picture of the aqua camo on yellow. I have a yellow (mango Hobie says) & just ordered some samples to see if that would help me make up my mind.
PA 14; 2012
Cape Fear River - NC
