It is currently Wed Aug 12, 2026 10:57 am
PostPosted: Sun Mar 30, 2014 5:16 pm
What are you guys using to maintain your drives
2014 Pro Angler 14 Dune
2013 Outback Papaya
Military Police, USAR SFC
Broward County Florida
PostPosted: Sun Mar 30, 2014 5:25 pm
Wash them with fresh water, spray them with a lube the doesn't attract sand. About once a month check the tension on your drive chains. That's about all you need to do. Every once and a while inspect all the moving parts for wear.
PostPosted: Sun Mar 30, 2014 6:01 pm
Ditto the above reply, with one added thing. There is a tiny allen head screw that holds the main SS rod in place. I am referring to the rod that holds the "flippers" on. If it gets looses, the rod can slide out while on the water. Since it is below the locks, it can drop off into the water and be lost. It almost happened to me. One "flipper" was hanging loose but was still attached to it's chain with the rod completely clear of it. Now, an allen wrench is standard equipment in my tool kit.
Richard Laughlin
Lafayette, LA
Finally Retired, Fish Beware!
2013 Hobie Pro Angler 14
2012 Hobie Pro Angler 12
2001 Hobie Hank Parker Edition Outback
PostPosted: Sun Mar 30, 2014 6:58 pm
Got my PA a few weeks ago and fish in salt water. What lube do you recommend?
PostPosted: Sun Mar 30, 2014 8:21 pm
This is the first of three FAQ's for Mirage Drive maintenance.....I use WD-40 on the chain .
viewtopic.php?f=60&t=12577
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Sun Mar 30, 2014 8:39 pm
Ditto on the WD-40. I rinse the sand and grit off the chains and sprockets after every outing, then spray them with WD-40.
Southwest Hobie Island Club
PostPosted: Mon Mar 31, 2014 5:39 am
I do the wash down every time regardless if fresh or salt just wasn't sure on type of lube
2013 Outback Papaya
PostPosted: Fri Apr 04, 2014 11:50 am
I give it a good spraying with the hose, and a little wd-40 anywhere I see bare metal. I wipe off the excess.
The only downside I have found with WD-40 is that it will leave a 'ring' in your Mirage-Drive well, but if you use some Dawn or other grease-cutting cleaner, it will come right off.
But I must say - after over a year of more than normal use, the drive is still functioning well and no noticeable rust.
I second the allen wrench suggestion! :D
PostPosted: Fri Apr 04, 2014 2:22 pm
Locally here on Cape Cod, the rumor is that Wd-40 actually attracts fish so we don't worry about wiping it off. Dunno if it's true, but that's what the ol' timers say. Anybody else hear that?
Know where you are, don't be a fool.
PostPosted: Sat Apr 05, 2014 11:44 am
WD-40 will "mask human scent" on tackle, lures, bait, etc......so fish like salmon, steelhead or trout that have good "noses", will avoid human scented items.
Dr.SteelheadCatcher
Warrenton, OR
