It is currently Wed Aug 12, 2026 12:55 am
 Post subject: Foam block placement?
PostPosted: Sat Mar 29, 2014 3:27 pm
I just installed my fishfinder and I had to remove the foam blocks to run the wires. I know they provide some structural support but I can't remembe where they go though. Can anyone she me a pick of inside the hull?
PostPosted: Wed Apr 02, 2014 6:36 am
Which Pro Angler, the 12 or 14?
PostPosted: Wed Apr 02, 2014 3:07 pm
For future reference in running wiring.....if you use a good old Stanley 1" wide tape measure, you can "fish/pull" the wires without removing the foam flotation blocks. :idea:
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Fri Apr 04, 2014 4:51 am
Its the 14 Jambone. I figured it out I forgot I have a buddy of just bought one too. He sent me pics of inside the hull. Ya Dr we weren't really thinking when we running wires. Thanks for the replies :)
PostPosted: Sat Jul 09, 2016 7:12 am
Got a used pa14 looked inside and found the foam blocks moved need a diagram showing Placement any help out there
PostPosted: Mon Jul 11, 2016 1:07 pm
I'm dealing with the same issue. PA 14 2012. I'm not sure what happened but all my blocks became dislodged as I was loading and most wound up in the stern. I'd like to make sure the correct blocks are in the right locations as I imagine they provide some support to the hull. I don't want to crack the deck while I'm standing.
Can someone post a diagram of the foam placement. Thanks.
PostPosted: Mon Jul 11, 2016 3:26 pm
Hobie should be able to send you a diagram of the foam block placement......since it's a pre-2013 model, there were fewer blocks.
I would call Hobie direct and cut to the chase.
Once you do get them where they belong, suggest using Gorilla tape to hold them to the hull so they won't move again. I have done this with my 2013 PA-14 and the blocks are firmly in place.
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Sun Jul 24, 2016 4:09 pm
Still waiting on hobie to get back with a sketch of foam block placement for a pa14 2015 ywar
PostPosted: Thu Aug 18, 2016 1:17 pm
Here is what they sent me - it is for a 12 - but I would love to have one for the 14 -
