It is currently Wed Aug 12, 2026 1:29 pm
 Post subject: Storing measuring board
PostPosted: Wed Apr 09, 2014 6:38 am
Hey guys like to add some eye pads or something to keep measuring device out of the way
What is everyone else doing?
2014 Pro Angler 14 Dune
2013 Outback Papaya
Military Police, USAR SFC
Broward County Florida
PostPosted: Wed Apr 09, 2014 9:15 am
I velcro mine on the left sidewall. Easy access, yet out of the way. It doesn't get in the way of my rods either, since I don't store them in the rod holders. They all stay behind me.
Richard Laughlin
Lafayette, LA
Finally Retired, Fish Beware!
2013 Hobie Pro Angler 14
2012 Hobie Pro Angler 12
2001 Hobie Hank Parker Edition Outback
PostPosted: Wed Apr 09, 2014 5:52 pm
For freshwater I use a Hawg Trough that I store on the YakAttack BlackPak using the Y/A Hawg Trough mounts. I use a para-cord leash as this board will sink in no time.
For salt water I use a DIY "Mudfish fish Jig" http://www.jaxkayakfishing.com/phpBB/topic23479.html that I store to the side of the seat...somewhat out of the way. No leash, as the poly-board floats.
PostPosted: Wed Apr 09, 2014 6:28 pm
Hey Greg
If you put some of that foam installation in the groves on the bottom it should float
2013 Outback Papaya
PostPosted: Wed Apr 09, 2014 7:18 pm
I simply drilled a 5/16" diameter hole in the end of the hawg trough, cut a 3' long, 1/4" diameter nylon line, fed it through the hole and tied a figure 8 knot....on the other end, I tied a bowline to a quick snap brass clamp....I installed a 1/4" nylon line across/in front of the seat where the quick snap is secured....this allows plenty of slack so you can use the hawg trough and not lose it overboard...no need for flotation.
I also connect to the "across/in front of my seat line" using quick snaps, the line I added to my net, fish rag, fish bonker and lip gripper...it's very handy and nothing gets lost overboard.
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Fri Apr 11, 2014 12:06 am
I have the same measuring device that LtFireDog has (yellow one) and I just slide it under the bungies for the front lid. It is a stretch to reach it when needed but it is out of the way when not needed.
PostPosted: Fri Apr 11, 2014 5:03 am
Instead of a separate measuring board mounted some where has anyone ever thought about just using self adhesive measuring tape ( you can get it at fabric stores like joann fabrics).
Just affix it to something already on the kayak in a handy spot. Like on a revo it could be stuck to the gunwale of the boat right next to you. On my TI I have a PVC pole just behind my seat for my light and diving and safety flags (we spearfish), just stick the tape to the side of the pole or the side of your paddle. We often take a catch cooler, you cold just stick the tape across the lid.
One less thing to have to carry around (or forget to bring along) if it's always on the boat. I tend to lose stuff like that overboard so the less I have to carry the better.
Just a thought
PostPosted: Fri Apr 11, 2014 1:34 pm
