It is currently Fri Jun 19, 2026 6:19 am
PostPosted: Thu Apr 17, 2014 6:08 pm
I am new to hobie cats as well as sailing. There are two hobie cats near me that a free but have no trailers. I am going to pick them up with my truck.
I was wondering what tools I will need to disassemble them so they fit in the truck bed and on the ladder rack.
I figure the four hauls and one mast on the rack. And all the other parts in the bed.
Thanks for the help
Brian
PostPosted: Fri Apr 18, 2014 8:13 am
Four bolts hold the trampoline frame to the hulls. You will need a big sand filled "Dead Blow" mallet or steel mallet and a 2x4. Remove the trampolines to make frame dis-assembly easier. Significant blows from the underside of the corner castings are required to drive the castings off the pylons.
I'd move assembled if possible. Renting or borrowing a trailer and adding 4x4 crossbars works. Way easier than dis-assembly.
Manual here: http://www.hobiecat.com/support/hobie-16/
PostPosted: Fri Apr 18, 2014 5:05 pm
Two adjustable wrenches and a dead blow hammer should get the job done?
Not an option to use a trailer I,ll have to take them apart to get them home.
Thanks for the manual pdf going to download and read through it now.
