It is currently Fri Jun 19, 2026 5:58 am
PostPosted: Fri May 02, 2014 3:45 pm
Hi Folks,
I have just received my H14 / H16 mast step link kit from Hobie Center UK and it appears I will need to drill a hole for the link pin on both my H16 mast(s) I have two and the H14 mast base.
The instructions state to use a 6.3mm drill bit, this is an unusual size of which I do not have.
I do have in my possession a 6mm and a 6.5mm HSS drill bit, do you think it would be adequate to use the 6.5mm or could I expect some issue by doing so?
I ask as this is the first time I will be attempting this procedure.
SRG
Hobie 14 Turbo (~1979)
Hobie 16 Carumba (1983)
Hobie 16 1990 (storm damaged)
Hobie 16 1996 (my latest)
PostPosted: Fri May 02, 2014 4:38 pm
I bet they said 6.3mm because it's 1/4". Not that precise.
'00 H16 #104691
Old Holsclaw trailer
My Hobie 16 pages
