It is currently Mon Aug 03, 2026 12:22 pm
 Post subject: Tramp repair
PostPosted: Sat Jun 21, 2014 2:41 pm
Any one have DIY tramp repair solution? I've got a small tare started at the rear of my port tramp. It's a mesh type tramp. The tare is right near the hull connection rope. I'm thinking about trying to sew it, but unsure if it will hold. Any input? I know I should buy a new one, but I can't help but try to repair something first. Just call me cheap :roll:
 Post subject: Re: Tramp repair
PostPosted: Sat Jun 21, 2014 3:05 pm
What I've done before with great results is to un-tension the tramp, mask off the area ( top AND bottom ) then mix up some epoxy resin letting it saturate into the fabric around the tear. After a day or two, remove the tape and tension up the tramp as normal. Won't tear in that area anymore!
Tim Grover
Memphis, TN fleet 134
Hobie 20! G-Cat5.0 and 2 Hobie 14's
Photobucket now wants $100 to post pics on forums......... pass.
PostPosted: Sat Jun 21, 2014 7:38 pm
That's the kind of idea I'm looking for. I can see that working quite well, maybe even add a layer of glass on the bottom. Thanks. Anyone else have any wisdom
PostPosted: Sun Jun 22, 2014 1:54 pm
I had a similar rip in the same place. I removed the tramp and sewed a strip of webbing onto the back side. Has held up for years.
Sent from my GT-N8013 using Tapatalk
Double Take
91 H18SX
PostPosted: Mon Jun 23, 2014 12:30 am
Not what you're looking for... but I cut my main halyard off and made a web as my port panel ripped apart during the first race of the year... it held up ok and kept the panel from ripping anymore, a nice lattice using the existing grommet holes.
I've replaced tramp straps with sail needles and line, and had a sail shop make some patches for me for more permenant solutions. The bigger question to consider is what the rest looks like... if everything is about to go, then a new tramp or newer tramp is probably in order.
Tom
Tom
Fleet 259, Central Coast CA
H18 ('81)
H18 ('85)
H20 ('97)
H18 ('78)
