It is currently Thu May 14, 2026 8:08 am
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
PostPosted: Thu Jul 10, 2014 10:44 am
I ordered a Sandpiper Sand Chair by Stansport from Amazon. It fits perfectly. I may not even use the wood blocks. It was $22 with prime shipping.
PostPosted: Tue Sep 02, 2014 1:14 am
Great idea to take a beach chair, but why couldn´t Hobie develop a better seat for the inflatables. Question to Matt: isn´t it possible to create a seat like the seat for the Outback 2015?
Thanks for an answer
serious
PostPosted: Sun Oct 05, 2014 3:56 pm
I bought an additional seat for the i9s and successfully installed it at the back of the i12s. If you look carefully, you can strap it on quite tightly using what's already there.
It's a 2014 i12s model though, so I don't know if it will work for older models.
There isn't much leg space so I reckon it's good for a small person and not an adult. I had successfully taken my 8 year old out quite comfortably for several hours.
PostPosted: Mon Mar 16, 2015 9:10 am
After different chairs, at last the perfect chair for my Hobie i12. Adsend kayak chair from Tracker Bass Pro. $87.photobucket[url][/url]photobucket[img][/photobucket
PostPosted: Sun Oct 18, 2015 10:08 am
I also find that the Hobie seat with the Mirage i12 just crushes completely and I end up flat on my back. I then got myself a stadium seat from Bass Pro...looked hopeful. The same thing happened! I don't know what I'm doing wrong in fastening it. I checked it on the ground and it withstood leaning back but as soon as I was on the water...I was flat on my back again. I'm no tinkerer or able to think of a way to make the seat stay upright while pedaling....any suggestions? S.O.S. I love my Hobie!
PostPosted: Mon Oct 19, 2015 12:38 pm
Just a thought......Have you inflated the hull with enough air?
Could it be "bending under pressure" when you lean back?
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Tue Oct 20, 2015 9:27 am
I will definitely give your suggestions a go...straps and/or rails of some kind. If that fails, I'll get a Sea Eagle seat and sell or give my stadium seat to someone who can use it.
I too wish Hobie would get a rigid seat for the 2015 inflatoyaks! Alas, I'm no marathon runner or ballet dancer (I was once upon a time ago but no longer) *sigh*
I will also see if I'm inflating the hull enough - though I do think I am.
Thanks you two...you've given me hope!
:D
PostPosted: Tue Nov 03, 2015 1:52 pm
Does anyone know if the new rigid seat fits and 2014 i12? I need to do something. I can not stand the original seat.
PostPosted: Tue Nov 03, 2015 2:14 pm
Does not fit older models. The new hulls have wider floors... smaller side tubes.
