It is currently Sat Jun 20, 2026 11:41 am
PostPosted: Sun Aug 10, 2014 1:37 pm
Sorry for this simple question.
Last time my boat was unrigged the shackle was disconnected from the mainsheet block rather than the traveller. I don't know if it takes a special shackle or not, however, now I can't connect the shackle to the block. The pin from the block doesn't seem to extend far enough to permit the shackle to be repined .
Possibly the person that unrigged it replaced the original shackle with another, it certainly looks small enough, same size pin as the one on the traveller.
Again sorry for such a simple question...
PostPosted: Mon Aug 11, 2014 8:44 am
There should be no shackle between the block and traveler. Should pin directly to the car.
PostPosted: Mon Aug 11, 2014 10:44 am
Isn't there is a U shaped bracket that goes between the traveler car and the block?Image
PostPosted: Mon Aug 11, 2014 3:34 pm
Same traveler car we use on the Hobie 16 and the block pins directly to the car.
The blocks come with shackles, but I wouldn't use them.
PostPosted: Thu Aug 14, 2014 2:22 pm
Thank you for your replies.
Mr Miller, I tried your suggestion and it works very well. Again, thank you for taking the time to respond.
imkj
