It is currently Tue Dec 09, 2025 8:31 pm
PostPosted: Thu Sep 04, 2014 4:43 pm
Hey folks - your thoughts on how you've solved this problem...
problem: the jib car on my Hobie 21SE releases downward. Even with the block adjusted in it's most upward position - when the jib sheets are under a lot of pressure - it's hard to release. No amount of slapping the jib sheet results in a reliable release. The problem is compounded when you get out on the wing and on the trapeze - of course this is when you want to be able to release the jib at a moments notice every time...
My jib car has a block with a becket and an adjustable cleat that the sheets are led through that pivots up and down. The block has a spring underneath it and is shackled to the jib car. I'll post a picture tonight. I'm sure it's stock / original equipment.
I've noticed that for the Hobie 16 you can get a jib car that releases upward - but I'm concerned that will not take the load of the H21SE.
Any thoughts on the best way to resolve this issue? Anyone else experienced this?
Thanks - Andy
Andy Gardner
Hobie 21SE "Lickity Split"
Cowan Lake Sailing Association
Foster, OH
PostPosted: Sun Sep 07, 2014 7:52 pm
In the Prosail series, Pete Melvin and his crew solved this problem by taking the cam cleats off the boat. John hand held the jib sheet. I changed mine to the big Harken fixed base swivel cams mounted in the track, that release upward, since my Wife crewed for me.
PostPosted: Mon Sep 08, 2014 9:54 am
Tom - got any pics of that set-up? "the big Harken fixed base swivel cams mounted in the track, that release upward"? Can you still buy that set-up? that could be the trick for my girlfriend as well!
cheer - Andy
Andy Gardner
Foster, OH
PostPosted: Wed Sep 10, 2014 11:57 am
I have found that I have better luck snapping aft and down with the emphasis on aft. I'm not sure why it works, but it does.
Todd
Hobie 21SE
Bellingham, WA
PostPosted: Wed Sep 10, 2014 3:48 pm
I removed the cams from the blocks and screwed them to the wings so I could quickly cleat or uncleat the jib from the trapeze. I like it so much that I mounted two more cams per wing, one for the main and two at different places for the jib sheet. This all worked well until I purchased new wing covers. I did not want any holes in my new wing covers ,so I filled in those old screw holes on the wings and have sailed without the cams on the wings.....I sure miss those easy to use cam cleats....... :oops:
Bill 404 21SE
PostPosted: Mon Sep 15, 2014 6:58 am
cheer - Andy
I'll post some later. I'm away from home, where the boat is, this week. They are the big cruiser swivels. I can't remember how I mounted them. That was 26 years ago. Very easy to cleat and release from any position.
It's this one: http://www.harken.com/productdetail.asp ... &taxid=375
Not cheap though. The cam swivels are mounted in a fixed position-not on a slide.
