It is currently Sat Aug 08, 2026 4:49 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Tue Nov 14, 2006 12:08 pm
i'm only back to the third hole from the top on the shroud adjusters as far as mast rake. I'll keep you posted as to what will be the fix.
__o__ _/) ~__
PostPosted: Tue Nov 14, 2006 3:19 pm
I took the rudders off and measured the holes. Compared to the template, holes were off center as much as 1/4 inch. So, I put them back together and adjusted the cam plate as far forward as possible, this time with a thin walled socket and was able to gain a little forward. I have just about eliminated slop on port side, starboard still has a little play, but not as much as before. I'll check the helm next time it blows when I am off.
Thanks for the support.
My dealer is Tackleshack, Pinellas Park, FL.
If still a bad or unexceptable helm, I'll take them back and give them your blessing :D
__o__ _/) ~__
PostPosted: Mon Nov 20, 2006 7:53 am
Update:
Sailed in 10-15 mph breezes with a fairly neutral helm.
Guess I just needed to adjust it correctly.
