It is currently Fri Jun 26, 2026 8:11 am
 Post subject: need some help
PostPosted: Tue Nov 11, 2014 7:12 pm
I was out fishing sunday and one of the mast for the fins broke off it was my fault its been bent a few times i tryed an easy out and it wont even turn need some ideas any help would be great i have a 2014 pa14
 Post subject: Re: need some help
PostPosted: Tue Nov 11, 2014 7:31 pm
Maybe just replace the sprocket and mast rather than struggle with it. The sprockets aren't too expensive ($18.99 USD / USA 11-2014)
PostPosted: Tue Nov 11, 2014 7:39 pm
Thanks i was thinking the same thing but i had to try
Is that price for the mast and sprocket
PostPosted: Wed Nov 12, 2014 6:49 am
Do you have enough to get a grip on? Try a little heat... NOT a torch, blow drier, heat gun...
PostPosted: Wed Nov 12, 2014 8:23 am
I dont have enough to grip i might try a soldering iron in the hole i got driled in it be for i give up
PostPosted: Wed Nov 12, 2014 8:47 am
I had to do this same repair a month ago and ended up doing this. A lot less hassle.
"I have always found it easier to show people what the coolest things about fishing are, rather than just tell them another fish story."
--Jose Wejebe
PostPosted: Wed Nov 12, 2014 9:12 am
That is just the sprocket.
PostPosted: Wed Nov 12, 2014 9:23 am
solder not strong enough to hold... will the EZ out bite?
PostPosted: Wed Nov 12, 2014 11:03 am
Thanks for the help im just going to replace the sprocket i was just trying to keep from takeing the drive apart
And no the easy out kept slipping when i put some good pull on it its a very good set i have there from snap on tools
