It is currently Mon Mar 23, 2026 8:30 am
Post new topic Reply to topic  [ 1323 posts ]  Go to page Previous  1 ... 69, 70, 71, 72, 73, 74, 75 ... 89  Next
PostPosted: Tue Nov 11, 2014 1:16 am
I use the extreme angle fair lead with the existing cleats. You can find them at west marine last I checked.
A swivel model would be nicer but I was waiting for other adventurers to break theirs, before I try it. :wink:
PostPosted: Wed Nov 12, 2014 12:02 pm
For'd or aft mounted? I normally sail from the after cockpit with the sheet rigged 2:1 through the after cleat. Looks like I could just bolt on the extreme angle fairlead to the for'd cam cleat and along with my tiller have a decent "proper" sailing setup for use on the hakas.
-RH
2013 Tandem Island "Victory Lane"
Oahu, Hawaii
www.rotorheadsblog.blogspot.com
PostPosted: Wed Nov 12, 2014 12:49 pm
Adding it to the forward cleat makes the most sense. Unless you own a TI3, in which case you do both. It's not just the side angles you are improving. The Haka seating angle is much higher as well. Solo or 2 up, the XAFL makes for smoother sheeting, especially from the port Haka.
With 2 on board, your crew should be maintaining the sheets though. I say "Make 'em work or make 'em swim!" :twisted:
PostPosted: Wed Nov 12, 2014 6:50 pm
Great...like I need a trip to West Marine. I can't get out of that place without spending at least a c-note.
Oahu, Hawaii
PostPosted: Thu Nov 13, 2014 1:52 pm
Especially if it's $tainless $teel! But think of all the $$$ you're saving on fuel..
PostPosted: Fri Nov 14, 2014 12:24 am
Nouhu, sent you an e-mail re hardware.
-RH
Oahu, Hawaii
PostPosted: Tue Nov 25, 2014 10:47 pm
Some clips demonstrating why the haka are the best sailing accessory.
In these winds the lee ama would have buried and caused drag. Getting out on the haka levels the TI and enables faster sailing:
PostPosted: Wed Nov 26, 2014 12:23 am
Man- those look comfortable. Put a great big :mrgreen: on my face!
Very nice trim, and a pretty dry ride, considering there are no spray skirts.
PostPosted: Wed Nov 26, 2014 2:11 am
Not wrong. That aircraft carrier of yours looks so stable. :wink:
PostPosted: Wed Nov 26, 2014 7:33 am
Very nice, Stringy. Nice vid, nice ride.
PostPosted: Thu Nov 27, 2014 8:56 pm
Thanks Nohuhu, Slaughter and Keith.
Slaughter's mention of aircraft carrier reminded me of the other great use for haka ...carrying stuff:
Here is the gear for a weeks camping trip
and how strapping it to the haka makes packing easier:
We could even sail with all that aboard:
PostPosted: Sat Nov 29, 2014 4:49 pm
Well, I'm impressed!
PostPosted: Sat Nov 29, 2014 5:39 pm
Yes, quite an impressive load. I have moved a lot of camping gear/supplies from the bow onto the hakas and rear storage area. It has greatly reduced diving of my AI--so much so, that diving is not an issue any more. We are starting our first camp trip of the season tomorrow--the first trip is always a bit painful. It is the "bar" by which all other trips are measure, i.e., you can always lower the bar on gear, supplies, etc., compared to that first trip. At least, I hope I can.
PostPosted: Mon Dec 15, 2014 10:46 pm
Hi.
I have started making some haka's roughly based on stringy v3 models.
I'm using less rungs - and I plan on using some diamond security mesh under a couple of layers of closed cell foam.
Does anyone know where you can get the aluminium mesh (preferably cheap)? I remember seeing some thrown out up the road a while back, now I'm kicking myself I didn't pick it up!
PostPosted: Tue Dec 16, 2014 2:06 am
I recently needed some for a cage I built around my car fridge. I found mine in a security door on the side of the road but here we also have a scrap metal guy who picks up all the kerb side recycling. My plan was to go and see him if I didn't find any roadside.
Brad
Long Jetty
Brad K
Papaya Tandem Island - "Dry Reach"
Lengthened Jet Ski trailer
"Kayaking Bob" Spray Skirts
Trampolines
