It is currently Tue Aug 04, 2026 10:38 am
PostPosted: Sun Nov 19, 2006 11:00 pm
Hi;
I find that the adjustment nut on my turbo fins loosens as I use the drive. I like to keep the fins fairly firm. I thought I remembered a post where someone suggested putting locktight on the threads. Can't find it. islocktight permanent? If so, does anyone have a less permanent solution to keep the fins at the setting i choose? Some way to make the adjustment stay in place? Does anyone else have this problem?
-Jonathan
PostPosted: Mon Nov 20, 2006 6:18 am
I had the same problem. The nuts would just work their way off and the fin would fall off. BTW the turbos float.
I did as Roadrunner suggested and replaced the yolk bolts with 1' ones. I also replaced the nurled nuts with nylock nuts and washers. Pedaling for hours yesterday with no loosinging of the fins. Problem solved,
See http://www.hobiecat.com/community/viewt ... highlight= for the whole discussion.
PostPosted: Mon Nov 20, 2006 6:46 am
easy tip:
when you cant find Loctite, use a drop of ladies nail polish. Works just as well and you can ALWAYS find that stuff.
Hell, use mens nail polish if prefer. I suspect it works just as well.
http://2gringos.blogspot.com/
PostPosted: Mon Nov 20, 2006 1:44 pm
canibul wrote:
easy tip:
Thanks for the link and advice. I live in The Castro in San Francisco; men's nail polish may be more plentiful.
