It is currently Wed Aug 12, 2026 1:11 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
PostPosted: Tue Dec 09, 2014 6:21 pm
Anyone know if any changes were made to the cockpit area between 2014 and 2015? Looking to put seadek on a 2015 PA 14 this winter but seadek is only showing kits for 2014.....wanting to see if kits will work on the 2015 models.
thanks
Hobie Fishing Team
Great Outdoor Provision Company Fishing Team
Polar Bear Coolers
Accent Paddles
Columbia Sportswear
Astral PFD
PostPosted: Thu Dec 11, 2014 8:10 am
I'm guessing the main floor areas stayed the same, but maybe Matt or someone that has the new 2015 and a 2013-14 can confirm. I did get an e-mail from SeaDek yesterday letting me know that they are almost finished with a template for the Pro Angler 17. I'll bet that took a lot more material! :D
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Unfair Lures Pro Staff
Ziptailz Ambassador
2015 Pro Angler 14 - Papaya
2018 Compass - Sea Grass
PostPosted: Tue Jan 06, 2015 7:42 am
Hi L2F!
I'm wondering if you ever tested this? I finally got my 2015 PA 14 and didn't want to splash her until I got this stuff installed.
As we are scheduled to have -15 degree weather this weekend, the only reason I'm not fishing is because of the SeaDek. At least that's the story I'm going with :wink: .
Just can't wait to spend the winter customizing the new yak, and I didn't want to pull the trigger with SeaDek if someone KNOWS it's not a great fit.
THANKS!
Saint
PostPosted: Tue Jan 06, 2015 3:30 pm
Saint wrote:
Hi L2F!
THANKS!
Saint
No I never got any responses other than the one above yours. I know that in the rear tank well area, the 2015 now has a small scupper hole in the middle where the 2014 did not. I believe everything else is the same. However, I'm not going to order the seadek kit for the 2015 until someone at seadek or Hobie can clarify the floor dimensions. Also, I've noticed that on seadek's website, they show several pictures where the front deck is different....some with 1 solid piece and some with multiple pieces in the picture. My question is if you use one solid piece, what do you do for the recessed areas where the factory padding is already there? If you pull that out, then the new seadek is not going to be thick enough to accommodate the deeper area for a solid piece. If you leave that in then the new seadek will not stick to the factory padding. I do like the 1 piece but need some input from someone as to what they did in those two footwell areas.
Hobie Fishing Team
Polar Bear Coolers
Accent Paddles
Columbia Sportswear
Astral PFD
PostPosted: Tue Jan 06, 2015 8:33 pm
I cannot confirm for sure that the floor dimension are the same but they appear to be. Below are pics of my install and I do not believe the new rear scupper will be an issue as appears to be in void in the padding anyway. If anyone wants to send me a PM with their email I will be glad to email the PDF of the CAD drawing they did for mine and you can see the various dimensions.
As for the factory foot pads I left them in and I am pretty sure SRAces left his in as well. Mine has been installed 10 months and I have had no issues and love it. There is enough area around the foot pads where the adhesive holds it fine.
Keith Black
2014 PA 14 Olive
2014 WS Ride 115x Camo
PostPosted: Sat Jan 10, 2015 1:26 pm
That's a good looking kit. I have a gray kit on my Jackson and plan on putting SeaDek on my 2015 PA12. Thanks for the pics
PostPosted: Mon Jan 19, 2015 9:34 am
Any idea what one of these SeaDek kits weighs? Thanks
PostPosted: Mon Jan 19, 2015 9:52 am
I put a kit on my Jackson Big Tuna, very lightweight. I would say under a pound.
Tight Lines
Jody
2015 PA 12 - Olive
Bison Coolers Field Staff
Slumberjack Pro Staff
PostPosted: Mon Jan 19, 2015 10:11 am
All that rubber under a pound? ?
PostPosted: Mon Jan 19, 2015 10:18 am
Believe it or not, its very lightweight rubber, around 5mm thick. They use a closed cell EVA material that is flexible and soft on the feet.
Tight Lines
Jody
2015 PA 12 - Olive
PostPosted: Mon Jan 19, 2015 3:27 pm
It weighs a few pounds...not under a pound. If I remember correctly, the shipping weight of the entire kit in a cardboard wrapping was around 7 pounds. So the padding itself should be well under 5 pounds...maybe less. There are cutouts that you do not use in that weight as well.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Ziptailz Ambassador
PostPosted: Mon Jan 19, 2015 9:47 pm
Sorry, I should have specified, the kit I installed on my Big Tuna, has far less material than what a PA requires. I've emailed SeaDek to inquire about 2015 availability for PAs.
Tight Lines
Jody
2015 PA 12 - Olive
PostPosted: Mon Jan 19, 2015 10:56 pm
Thanks. I ordered some color samples from them today.
PostPosted: Wed Jan 21, 2015 9:00 pm
SeaDek quoted me $335 for the camel color for my 2015 PA 12.....I'll wait.
Tight Lines
Jody
2015 PA 12 - Olive
PostPosted: Thu Jan 22, 2015 11:31 am
That is a really nice looking kit. It is making me re-think my planned purchase of a papaya colored PA14. I don't see many color combos that appeal to me with yellow color but your combo looks sweet.
Well done!
