It is currently Wed Aug 12, 2026 1:11 pm
PostPosted: Fri Jan 23, 2015 12:05 pm
Hi all
had the unfortunate event happen in that the knot in the rudder lift handle slipped and the cable ended up inside the hull. Now I am struggling to get it through the tubing from inside the hull to the outside. I have a 2013 PA 12. Please help. :oops:
Tight lines and calm seas,
Rocket
PostPosted: Fri Jan 23, 2015 2:42 pm
Try feeding 20# mono from topside into tube and tie onto cable and pull back out.
PostPosted: Sun Jan 25, 2015 5:41 pm
you can also use very thin leader wire... I don't use it for leader but I always keep some around to sneak things thru tiny holes...
