It is currently Sat Aug 01, 2026 5:25 pm
 Post subject: Hobie Rudder Shaper Tool
PostPosted: Sun Nov 26, 2006 5:26 pm
Does anyone remember the Hobie rudder shaping tool? I believe that it had an upside down "V" that could easily shape the rudders. Are they still available?
 Post subject: Use a pair of scissors
PostPosted: Sun Nov 26, 2006 6:10 pm
Just use a pair of and then file a little flat on trailing edge..
Doug
PostPosted: Sun Nov 26, 2006 6:22 pm
Just use a pair of
scissors
Not your wifes, get yourself a pair at the hardware store for your sailing kit.
Fleet 297
PostPosted: Sun Nov 26, 2006 8:56 pm
They haven't been available for years but I've got one. They work great on the original lexan and EPOs. Two passes and your rudders are mute.
They're tricky on the newer rudders. If you don't have a steady hand you'll end up with a scaloped trailing edge.
PostPosted: Mon Nov 27, 2006 2:19 am
How do you hold the scissors steady? How wide should the scissors be open?
