It is currently Wed Aug 12, 2026 10:07 am
PostPosted: Tue Feb 17, 2015 8:57 am
Guys....
I am lucky enough to have a Pro Angler14 arriving shortly...
Now I am looking to make one of these stands for it out of PVC pipe probably, but! Could anyone give me the width dimensions that the two upper struts are apart please. As I would like to get this built before it arrives to use as a work bench whilst adding my upgrades to it.
I would also like to get a trailer built and will probably use 3" pipe for the supports....so if someone could give me the above information I would be grateful. I searched previous threads but could not find this information.
Tight Lines....
Looking for that fish bigger than the Kayak
PostPosted: Tue Feb 17, 2015 10:16 am
I have a wooden stand with the PVC running the length of it for the PA to sit on and the PVC should be 11" apart from centerline of each pipe (i used 3" PVC as well). that should fit in the grooves of the PA properly and give it a nice comfy seat. Not sure of the stand you are talking about but for the trailer i would think that is how far apart you want the PVC beds. Hope this helps and i will verify that i remember correctly. Go Easy
PostPosted: Wed Feb 18, 2015 11:50 am
Excellent, thank you for the info
