It is currently Fri Dec 19, 2025 7:04 pm
PostPosted: Wed Mar 04, 2015 5:59 pm
I decided to add a switch panel to my PA. I'm going to wire a stern light and some cockpit lights. I swapped out the accessory socket for a USB socket to charge my iPad mini.
PostPosted: Wed Mar 04, 2015 11:32 pm
man i have a panel but just can't bring myself to cut into it yet. looks great tho, what all do you run off of it and what size battery you use to push it all?
PostPosted: Thu Mar 05, 2015 2:03 am
I wanted a switch panel but didn't really want to cut that large of a hole in my 8 month old PA14. Fortunately it was such a size that it fit almost perfectly into an existing hole. I removed one of the forward horizontal rod holders and put the switch panel in its place. I had to square off the hole a little bit but it as otherwise perfect fit. I rarely used both of the rod tubes, and if I ever get tired of thee switch panel I can remove and slide the tubes right back in.
The switch panel came with 4 switches, accessory plug and volt-meter. I replaced the accessory plug much like you did with usb plugs. If I can figure out how to post pictures, I'll post one of the install.
Jeff
Jeff
KansasYaker
2014 - Pro Angler - 14 - Upgraded H-Rail Kit
PostPosted: Thu Mar 05, 2015 2:36 am
There will be a stern light, LED cockpit lighting (under mounting boards), Vexilar Sonar Phone and USB is for iPad mini. I will use a 12V 9ah battery. I will have a couple extra switches for and future add-ons.
PostPosted: Thu Mar 05, 2015 5:38 pm
My setup with red led lights turned on.
White leds
My battery.
I have red and green led navigation lights on the bow, a stern light pole, both red and white led deck lights under both mounting boards and lowrance elite 4-hdi.
I have the battery in a pelican case that I store in the hull on a piece of memory under the seat.
Jeff
KansasYaker
PostPosted: Thu Mar 05, 2015 6:14 pm
You should get a few hours out of that battery.
PostPosted: Thu Mar 05, 2015 6:22 pm
I have to admit that I haven't gotten much use out of the lights yet. Being new to kayak world as of May of last year, most of my time on the water has been in the daylight hours. The lake I fish on has absolutely no lights not even on the boat ramp. I don't want to say that I'm afraid of the dark....but.... Going to make more of an effort to do more night fishing this year once it warms up some especially since most of the fishing I do is for walleye anyways.
The battery wasn't cheap, I think I paid $200, but it only weighs like 2 lbs. Just operating the lowrance for 5 or 6 hours a trip about 4 or 5 times a week, I've never even come close to running it down.
Jeff
Jeff
KansasYaker
PostPosted: Mon Mar 09, 2015 5:23 am
Kansas Yaker, where did you order your switch panel from? Like the way it fits the space. Is there a cover for the USB port and is the panel waterproof.
Just a Kid to the End
PostPosted: Mon Mar 09, 2015 1:53 pm
I bought them both from Amazon. The switch panel came with an accessory plug that I replaced with the USB outlets. Yes, there is a cover for the USB. It is kind of folded up in my pictures.
Amarine Switch Panel - Says it is currently unavailable on Amazon. I'm sure you can find it somewhere perhaps ebay or maybe a marine dealer online.
http://www.amazon.com/gp/product/B00MWS108O/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1
USB Charger Socket
http://www.amazon.com/gp/product/B00IRJH8CE/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
Jeff
Jeff
KansasYaker
PostPosted: Mon Mar 09, 2015 1:58 pm
This one appears to be the same one from a different seller on Amazon.
http://www.amazon.com/MyBest-Splash-Proof-Toggle-Switch-Voltmeter/dp/B00MDADIPY/ref=pd_sim_sbs_sg_42?ie=UTF8&refRID=1JKN4F2FSCACNENM6RKB
Jeff
KansasYaker
PostPosted: Mon Mar 09, 2015 4:45 pm
KansasYaker wrote:
Appreciate the help. Tight lines.
PostPosted: Wed Mar 11, 2015 6:11 am
I got the LED's fastened under the mounting boards.
They should add a little light.
Vexilar Sonar Phone mounted and wired up.
And the rear all-round pole light wired and mounted...just need a flag.
PostPosted: Thu Mar 12, 2015 12:41 am
Very clean install.
Your light pole looks pretty tall. You might be able to use it as a flag pole. Looks like that thing folds down too. If so, do you fold it down for transport?
Jeff
KansasYaker
PostPosted: Thu Mar 12, 2015 3:38 am
KansasYaker wrote:
Very clean install.
Yes, it doubles as my flag pole as well, I just haven't added the flag yet.
The pole is actually removable for transport... I've added wire connector so I can disconnect it.
PostPosted: Thu Mar 23, 2017 6:24 am
Reviving an old thread here. Just want to say thanks to Mtmouse and others for the direction here. I pretty much copied the hatch install design. I decided not to cut the bucket and just do the permanent switch install (might change this). I also mounted a fuse box (blue sea 5025) with grounding posts on the underside/bottom of the bucket. I got the new Nocqua 10ah pro power kit so I just installed a grommet in the bottom of the bucket and ran the power to the fuse block. I opted for led strips for the white light that I covered in epoxy to waterproof and I installed a single submersible red led trailer light from HF. I hope to add a stern light at some point also.
