It is currently Thu Aug 20, 2026 10:40 pm
PostPosted: Fri Mar 27, 2015 3:13 am
I have just started to accessorize my 2015 Oasis for sailing but I am having trouble finding enough flat deck on the gunwale to mount the center tube without interfering with the front seat, the mast mount or the rear mirage drive. Where there is enough flat deck the center tube is too short to fit between the mounts. There is ample space behind the rear seat but I am not confident that it would be the most effective location.
Am I overlooking something simple or will I need to mod it to make it fit? If anyone has completed the same install I will gladly accept some advice.
Many thanks,
Swamped10.
PostPosted: Mon Mar 30, 2015 7:03 am
I have installed my sidekick behind the rear seat. It work juste fine
PostPosted: Tue Mar 31, 2015 2:02 am
That is where I ended up putting them although the lumbar support adjustment knob catches under it if the front passenger is slightly reclining. That having been said, the front seat wouldn't be able to recline that far with the mast installed so I will just leave the center rail off for peddling trips. Many thank for the reply and to those that took the time to read the post.
