It is currently Thu Jun 11, 2026 3:19 pm
PostPosted: Sun Apr 05, 2015 11:21 pm
Picked up my new AI 4 days ago. Have been out twice since then and I am very impressed. I won't go and give a detailed review, as Yakass has done a brilliant job of that.
But I must say that the seat is super comfy. The cut in the sail allows you to see much better and no ducking to tack anymore. As far as speed goes, the new AI is noticeably faster in all cases with the exception of running straight down wind. The ride is higher and drier and smoother. So far pushing it downwind I didn't bury the nose, where the older AI right beside me did.
What a brilliant BEAST.
Did just a couple of easy mods, as shown in the photos. Lined the front hatch with thin closed cell foam to stop things bouncing around. Changed the control lines as I did with my old AI. Then added Kayaking Bob's Spray Skirts.
So far I am very impressed.
Here is a short youtube video. https://www.youtube.com/watch?v=wAvoUDXp6bI
2021 Dune Hobie Lynx
PostPosted: Mon Apr 06, 2015 4:11 am
Nice post. Good pictures, video. Thanks.
PostPosted: Mon Apr 06, 2015 5:15 am
That foam in the front hatch is a great idea. Did you attach it in some way ?
Did you change to wide angle fairleads just for sailing from Hakas ?
Chris
PostPosted: Mon Apr 06, 2015 10:38 am
Attached it with just a few blobs of marine sealant to stop it moving.
Changed to keep the controls close at hand and to keep the furling line away from my feet.
It was the only double cleat I could find.
Chris
PostPosted: Mon Apr 06, 2015 10:42 am
Where'd you find the blue closed-cell foam? Goes great with the Dune!
PostPosted: Mon Apr 06, 2015 11:59 am
It's just a cheap sleeping mat for camping. Bought it at Clarke Rubber.
PostPosted: Mon Apr 06, 2015 3:19 pm
KMart has 12mm closed cell foam yoga mats for $12 I believe.
PostPosted: Mon Apr 06, 2015 6:29 pm
Yeah I saw those. They were too narrow and wouldn't go up the sides of the hull enough.
PostPosted: Mon Apr 06, 2015 8:03 pm
I like the alteration to the mainsheet jam cleat. What did you use? I'm also wondering what is the material that is between the bigger jam cleat you installed and the original jam cleat and what is its function?
PostPosted: Tue Apr 07, 2015 10:41 pm
The cam cleat is a laser cam cleat. It is used for the main sheet and furling line. I made an aluminium plate for it to sit on. (Added strength)
PostPosted: Wed Apr 08, 2015 12:12 am
thank you!
