It is currently Thu May 14, 2026 8:32 am
 Post subject: Fishfinder Noise Filter
PostPosted: Wed Apr 01, 2015 4:43 pm
I have a Lowrance Elite 4 dsi fishfiinder that just went blank. Seems the noise filter in the wiring from the battery is not passing battery voltage to the fish finder. I removed the filter & hooked the battery up once again & now fish finder powers up. Haven't been out on the water to test it out yet, but is this noise filter needed? The only other electrical device I have on board is the Evolve 2 motor.
PA 14; 2012
Cape Fear River - NC
PostPosted: Wed Apr 01, 2015 6:35 pm
Simple/cheap "Noise filters" usually comprise a higher-perm-lossy ferrite, toroidal core that the cable is passed through.
It makes no sense to me that removing the filter changed the operation of the fish finder. Maybe a bad electrical connection or the unit is flaky?
Usually these filters are needed to trap/absorb higher frequency noise that other on-board sources generate.....like a electric motor control switching circuit or ignition noise from a gas engine, etc.
Since you have the Evolve 2 motor, if anything the filter is redundant or not needed IF the Lowrance operation is normal after the filter has been removed.
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Fri Apr 03, 2015 4:54 am
Thanks Dr.
When I meggarred the two wires on the noise filter, the black had continuity & the red was open circuited. That's why I removed it & hooked it up without.
PA 14; 2012
PostPosted: Tue Apr 07, 2015 2:34 pm
Does anyone know where a replacement noise filter can be purchased? Can't seem to find a vendor or part number on the Lowrance or Navico websites.
PA 14; 2012
PostPosted: Tue Apr 07, 2015 3:42 pm
Why don't you cut off the noise filter(if it is permanently attached), solder the wires together and make sure your finder is working. Then use a standard ferrite core noise suppressor. They are pretty much all the same.
Waterman at Work - Kayak Fishing Photos, Video,Kayak Rigging - Blog
PostPosted: Tue Apr 07, 2015 6:55 pm
If your unit is still under warranty, I would contact Lowrance about the problem.
It sounds to me that the "noise filter" is a shielded box with an input and output cable???
If this is the case, the filter is a pi filter that has both an inductor(s) and capacitor(s) inside the box and is more than a single turn, of the cable, passing through the do-nut hole in a ferrite core.
It could be the fish finder has an intermittent problem....cable, connector, high resistance on connector pins????
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Wed Apr 08, 2015 5:40 am
Thanks Dr. for your help.
It looks like this:
https://www.flickr.com/photos/93566836@N02/16869785227/
Will try the PA today without the filter.
[url][URL=http://s1249.photobucket.com/user/xxprotegexx/media/fish%20finder%20how%20to/IMG_20140102_171459_055.jpg.html]Image[/url]/url]
PA 14; 2012
PostPosted: Wed Apr 08, 2015 6:07 am
The filter is a "typical" ferrite core where the cable passes through the hole in the core.
If your fish finder works without the filter, then the wire through the filter has a bad connector termination or has a broken/open wire.
Easy to check each wire for continuity by using an ohm meter.
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Wed Apr 08, 2015 3:32 pm
Thx Doc....went out today w/o the noise filter attached...did not see any issue w/ the fishfinder/chartplotter/sonar instrument...even w/ the Torqeedo motor going full blast.
Guess I will leave it as it is.
PA 14; 2012
