It is currently Fri Jun 19, 2026 10:40 am
PostPosted: Sat Apr 18, 2015 4:09 pm
Just had my hobie dealer install these...shouldn't the hole for the bungee cord be on the actual tiller arm, not the cross bar?
85 Hobie 14 "mello yello"
PostPosted: Sat Apr 18, 2015 6:19 pm
Yes, mine are on the tiller arm but i see a benefit to yours. The bungees tension will keep the threaded adjustment that you've set stationary for when you re-assemble not to mention sliding your tiller extension/hotstick under the bungee to keep your rudders locked up whilst backing your boat on the trailer down a ramp. My hobie 20's crossbar adjuster is no where near where i left it by the time i trailer my boat to a regatta or even to the house an hour away from the lake.
Tim Grover
Memphis, TN fleet 134
Hobie 20! G-Cat5.0 and 2 Hobie 14's
Photobucket now wants $100 to post pics on forums......... pass.
PostPosted: Sat Apr 18, 2015 6:44 pm
Thanks, I just wanted to make sure that it's ok to sail, every picture that I could find of the H20 connectors installed looks like this: Image
PostPosted: Sun Apr 19, 2015 7:50 am
Also noticed that the adjustable end of the tiller crossbar is riveted. Shouldn't the adjuster be screwed in, not riveted in the event that the plastic threaded part needs to be replaced?
PostPosted: Mon Apr 20, 2015 5:30 am
If you ever need to replace the female threads of the adjuster, that rivet can be removed fairly easily drilled out.
PostPosted: Mon Apr 20, 2015 9:19 am
I never understood why Hobie didn't put a set screw on the adjustment end of the tiller adjuster. That seems like a no-brainer to me. Instead we have to wrap the adjuster in tape to keep it where we want it??? :roll:
