It is currently Mon Aug 03, 2026 1:21 pm
PostPosted: Fri May 01, 2015 7:01 am
I only ever use the one. Are you technically supposed to put a separate shackle in the lower hole for the luff tension line? I've just been running that line through the same shackle as the jib tack.
PostPosted: Sun May 03, 2015 9:32 am
Looking at the hobie 18 assembly manual, it appears that the "proper" way to rig the furler is to use a Clevis pin and split ring through the top hole to set the mast rake/forestay (page 9, figure 18), and attach the tack of the jib using a shackle through the lower hole (page 16, figure 39). Interesting, I had never noticed that detail before. I had always used a shackle through the top hole to secure the forestay, and attached the tack of the jib with a second shackle through the loop of the first one. I may have to try doing it the "right" way sometime and see how it works out! :)
Hobie 18 assembly manual: http://static.hobiecat.com/digital_asse ... Manual.pdf
Mike
'78 H18 (unnamed) sail #14921
'08 H16 sail #114312
'97 H21SC sail #238
