It is currently Thu Aug 20, 2026 10:10 am
PostPosted: Mon Jun 29, 2015 12:28 pm
Hi there,
Can someone please help with some information, I am based in England and looking to purchase a used adventure, and need to know what how do you tell the age of manufacture of the hull and are there any things I should be looking out for?
Regards Kevin
PostPosted: Mon Jun 29, 2015 1:27 pm
The serial number includes year of manufacture and model year.
http://www.hobiecat.com/articles/boat-serial-number-location,15/
PostPosted: Mon Jun 29, 2015 10:47 pm
Thanks Matt
Are there any areas/parts I should look closely at for damage or wear.
Regards Kevin
PostPosted: Tue Jun 30, 2015 1:07 pm
Hi Matt
Some more help please, I have been offered two adventure islands and ask if you can confirm the serial numbers are correct.
Red hull USHCCRO817t011
Yellow hull USHCCRO555H011
Is there any thing on these I would need to check before buying.
Regards Kevin
PostPosted: Tue Jun 30, 2015 3:51 pm
HCCR0817I011 (HCCR "0 or ZERO" not Letter "O") (I not T)
HCCR0555H011 (HCCR "0 or ZERO" not Letter "O")
Both valid numbers sold to Hobie Kayak Europe.
Check that all of the parts are there. Inspecting for wear should be straight forward. What looks good is likely good.
PostPosted: Tue Jun 30, 2015 3:56 pm
Do a low pressure leak test with soapy water spray bottle. Lots of threads on the forum depicting this. Look for leaks in the plastic, below the waterline especially. The steering line ports and various hatches can leak slightly.
The Wind Is Your Friend...
