It is currently Wed Aug 05, 2026 1:04 am
PostPosted: Fri Jul 03, 2015 12:55 pm
I have recently had to deal with a flooded hull on multiple occasions with my Island (crack in the hull). I carry of course a hand bilge pump with me. Having used it a couple times now, though, I have to say that it takes both a lot of time and a lot of effort to empty a hull. In rough conditions I actually think it would be close to impossible.
So I recently picked-up one of these:
TeraPump TRHA01 Battery Operated 2AA Pump
It's a battery-powered fuel pump but works with water. It is not fast but it will empty the kayak at least as fast as a hand pump and do so much more easily. I found it works well -- unlike the hand pump you could probably even empty the hull while your body was in the water. The shape also makes it easy to empty the hull on land: I can tilt the nose up and stick the long pump all the way into the other nose and empty the boat completely.
For $18 I consider it a virtually a must-have accessory. FYI...
(Hmmm... I just read this and it almost sounds like an ad. I have no commercial gain from this! :D )
PostPosted: Fri Jul 03, 2015 6:59 pm
If I could find a small automatic bulge pump with a float or something that activates it automatically I would buy and rig into my TI in a heartbeat. Something really tiny battery operated with maybe a quarter inch output hose. Every weekend I go out and when I get home I have to vacuum out between 2cups and a quart of water out of the hull (this gets really old). I suspect the water comes in a little bit from everywhere not just the main hatch. I was out offshore today and it was a little rougher than I usually prefer (2-3 ft chop). I suspect the water is coming in everywhere because when pounding very hard at high speed you can see the entire boat bending and twisting as you crash over the chop. I was out offshore on the 6.5 mile superboat race course practicing for tommorrows race (well pretending anyway (lol, don't think I set any lap record, but I had a blast)). I was hoping to get some video of them out there practicing on the racecourse, didn't see a single one (last year I saw and videoed about 15 or 20 different super boats). I just walked out and measured about 3 cups in the hull, which is actually ok, I usually take in much more when I'm out hot dogging off shore, so I guess it was a good day (lol). I had fun anyway.
Still want an automatic pump though.
Edit: I often do 50-60 mile day trips and it concerns me that the boat takes on water, the rough it is normally the more water comes in. Not sure what I could do about the water intrusion, thus the automatic bilge pump.
FE
PostPosted: Sat Jul 04, 2015 3:54 pm
I've been thinking along those lines as well. There are some threads in these forums of people wiring up an automatic pump and battery... of course that involves drilling a hole in the boat for output which I admit I'm always reluctant to do... it would be nice if one could just hook a hose up to the existing drainage port with a valve of some sort. But short of that, a battery pump you can just use by opening the center hatch on occasion seems like a reasonable compromise.
If you search "bilge pump" in these forums though you will see totally automatic setups people have done.
PostPosted: Mon Jul 06, 2015 7:30 am
Sounds like you need to get the crack fixed for take it to a dealer for repairs... In rough conditions you are not safe even if you are wearing your PFD. Sounds like you are in the ocean/gulf/sea, and you never know when a rogue wave might apear out of no where... Just my 2 cents worth... Hope things go well in your adventures in the future... Good LUck
PostPosted: Tue Jul 07, 2015 3:59 pm
Thanks, yes I've got a cracked drive well and I am getting it replaced. My only point of this thread was anyone may need to pump out their hull in an emergency and the manual pumps are a lot more difficult to use than I think people may realize... and a battery-powered one is a very small investment for an emergency.
