It is currently Mon Aug 03, 2026 6:55 am
PostPosted: Mon Jun 07, 2004 6:11 pm
My centerboards (daggerboards?) were a pretty chewed up on the backsides after two seasons of use. I am concerned that if I used a standard fiberglass patch, the boards might not fit in the hull slots.
Please let me know if there is a good alternative or if I shoulod be concerned with that possibility.
Thanks.
~Josh
 Post subject: Dagger board repair
PostPosted: Mon Jun 21, 2004 10:07 pm
How badly are they damaged?
I repaired mine last season using only fiberglass resin no patch screening.
There were 1/2" - 3/4" pieces out of the edges.
No issues with the repair after a hard season.
Just make sure you don't change the shape and you should be fine.
Good luck
