It is currently Sun Jun 14, 2026 1:24 am
PostPosted: Mon Apr 06, 2015 8:34 pm
I am new TI owner using the Hobie Trax "2-30" kayak cart. I sometimes want to remove the wheels and stow them in the kayak, but I've found the cotter pins on the cart to be a bit of a pain to put on and take off when they're wet. I'd like to replace them with lynch pins, but I can't find any that are small enough. The smallest size seems to be 3/16" diameter, but it looks like I need 1/8" diameter. If anyone knows where I could find 1/8" diameter lynch pins, or could suggest some other solution I'd appreciate it.
PostPosted: Tue Apr 07, 2015 8:19 am
You could add a short line to use to pull them. Or simply pass a line through when you want to pull them.
PostPosted: Tue Apr 07, 2015 12:24 pm
Matt,
That's a good idea for removing them, but it doesn't help with getting them back on which is the more difficult of the two procedures.
I had a kayak cart made by TMS that had lynch pins on the axles, and I think they would have been small enough. The same cart is still for sale:
http://www.amazon.com/TMS-CART-CANOE-KAYAK-KY001-Carrier-Transport/dp/B0082365AQ
but unfortunately I can't find a website or any company contact info.
PostPosted: Tue Apr 07, 2015 1:34 pm
We use a lynch pin in some of our carts...
80046021 PIN, QUICK CLIP KAYAK CART
The pin looks to be 3/16" diameter. The limiting issue is the length of the axle beyond the hole. You can't flip the ring over if the hole is too far inboard.
PostPosted: Sun Jul 12, 2015 6:31 pm
I have had 2 of these pins that Matt pictured on my PA (80046021 PIN, QUICK CLIP KAYAK CART) fall out and become lost in the water. Any alternative for those?
PostPosted: Wed Jul 15, 2015 3:46 am
Can you drill the holes out for a 3/16" pin ?
Chris
