It is currently Tue Feb 10, 2026 9:48 pm
 Post subject: Mirage Drive upgrade
PostPosted: Mon Jul 13, 2015 10:37 am
Is there a parts list or kit to upgrade my 2013 mirage Turbo ST fins) to the 2015 model?
 Post subject: Re: Mirage Drive upgrade
PostPosted: Mon Jul 13, 2015 1:37 pm
I upgraded my 2013 PA-14, ST Turbo Mirage drive last January and these are the individual part numbers needed to convert it to the GT drive.
1 each idler pulley-GT with bearings P/N 81123001 @ $7.00
2 each sprockets GT with bearings P/N 81127001 @ $22.00 each
2 each drum-GT with bearings P/N 81175001 @ $40.00 each
And lastly, since the drums did not have the pedal adjustment decals installed as I expected, I ordered after the fact;
2 each decals, pedal adjustment P/N 81172001 @ $0.70 each.
The total is $132.40 list price and I can confirm, it's worth the $$, time and effort to make the GT conversion
Here is the link to make the upgrade http://static.hobiecat.com/item_attachm ... 01z117.pdf
Although it does not show greasing the bearings, I used Evinrude Johnson Triple-Guard Grease..it's blue, totally waterproof and won't wash out in use.....the stuff is really sticky and you don't need much grease to do the job.
Make sure you use a small amount of "Blue Loctite" on the turbo fin threaded shafts prior to screwing back into the new sprocket inserts.
Good luck!
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Thu Jul 16, 2015 12:40 pm
Thank you Dr.SteelheadCatcher. I'm heading to east Baja for the month of September. The extra parts can be spares.
PostPosted: Thu Jul 16, 2015 12:59 pm
How many of each part did you order? The math doesn't add up
in total do I need ?
2 idler pulley-GT with bearings P/N 81123001 @ $7.00
4 sprockets GT with bearings P/N 81127001 @ $22.00 each
4 drum-GT with bearings P/N 81175001 @ $40.00 each
Thanks and sorry for my confusion
PostPosted: Thu Jul 16, 2015 2:58 pm
You only need 1 idler pulley....it's the "round one up front" ...unless you have 2 Mirage drives to up date....I thought you were doing just a single drive, but adding in spares, double the quantity in my previous reply.
Don't forget the "decals" too.
So, to upgrade 1 Mirage drive, the list price for all the items is $132.40 or $264.80 for 2 drives/spares.
Your Hobie Dealer can easily reconfirm these P/N's and cost.
Hope you have a good/safe time in Baja.
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Thu Jul 16, 2015 3:53 pm
I easily picked up speed without actually peddling harder. I find I need to purposely slow down my cadence from time to time to bring my speed down.
