It is currently Wed Aug 12, 2026 6:50 pm
PostPosted: Sun Mar 15, 2015 12:19 am
My last kayak was a Pro-angler 12. On the new Outback, the place is more limited, so I had to think of rigging deeply.
The first thing that I looked was the possibility of using a transducer with a side view.
The middle hull being lower than the lateral hulls, down slightly probe after cutting protection allows to place it in this wise place:
With a fairly simple system (but long to implement) square slider:
one can lower the probe out of the cavity:
This eliminates the need for mounting on side arm (tedious to mount / unmount and always difficult to have a piece outside the kayak)) or paste it into the shell (with the problem of hatching by tough weather ).
The second point was to turn round hatch a more convenient rectangular hatch, but without having to straddle legs outside the kayak. I placed it in the direction of kayak:
I chose white for harmony with the dune color, but also the least sensitive to the sun.
Two collapsible bowls area comfortably store equipment:
The lithium battery fits into the tailgate, well protected:
The "missile launcher" style rod holders are useless to my taste. those molded of origin are too far, and those that are placed on rails or pedestals do not suit me because I do not like the rods upright on the kayak.
So I installed both horizontally rod holders:
This allows the rods tidy along the hull and protect at beach landing. Drive elastic can be used to maintain them.
A tube cut in a plumbing fitting allows placing a rod vertically to achieve a node for example:
The paddles are placed on the back because there either I do not like them on the sides:
Back and forth trolley:
Why two trolleys? Because with a single rope anchor, floating or not, tends to go under the hull.
With this system, I send either the front or the back, directly on the side.
The Humminbird fishfinder Helix 5 is placed near the seat for readability. Below VHF natural place:
To easily load the kayak on the gallery, no need for sophisticated and expensive system. A kart tire stuck in the rudder can lift the kayak without it slipping:
Simple, easy and free!
sorry for my poor english... :oops:
François - French Hobie fishing team - Outback 2019 papaya
ex: Revo 13 2007 - PA 14 2008 - PA 12 2009 - Outback 2011/2013/2015 - Compass 2017
PostPosted: Sun Mar 15, 2015 5:27 pm
So how do you like the Helix? I'm leaning heavy toward the 899ciSI.
Hobie Pro Angler
PostPosted: Sun Mar 15, 2015 11:56 pm
I told you on another post.
It's perfect but you need to be close ( wherever it's better for access on buttons)...
PostPosted: Wed Mar 25, 2015 6:03 am
Some improvements.
I bought Tubtrug flexible plastic bucket.
had to force to get it in. It allows to have a large loading volume:
Stuffs are dry and do not slip inside the kayak.
For central hatch I found a large folding bowl Ortlieb:
Easily fit a mac, a vest, a few lures boxes and snack ... :)
PostPosted: Wed Mar 25, 2015 6:24 pm
felvic wrote:
Thats a great idea. I don't have the tools to do it myself.. gonna check my dealer to see what it would cost in labor. How is it working out for you so far..is there any concern about structural integrity when standing up on the box? I stand a lot on my Outback.
PostPosted: Wed Mar 25, 2015 11:07 pm
What's difference with a round hatch?
In precaution, I put two square tubes inside the hull:
PostPosted: Thu Jul 16, 2015 9:37 pm
Felvic,
It took me some time to go to the go-kart track but yesterday I got a cast off tire. I drilled a couple of holes and tide some rope so it will loop around the tail of the boat. I loved your idea and now I love using it as it protects the back end of the boat when I load and unload from my car roof.
merci beaucoup
https://www.flickr.com/photos/a8cmg/
https://www.youtube.com/user/mastery415/videos
PostPosted: Thu Jul 16, 2015 11:26 pm
Clintvava wrote:
Felvic,
merci beaucoup
You're welcome! :wink:
PostPosted: Fri Jul 17, 2015 11:37 am
what size Tubtrug is that in the front hatch?
PostPosted: Fri Jul 17, 2015 11:54 pm
35 liters...
